Topic: Ambient ceiling lighting project for Dolby 5.1 sound for PC (Read 2033 times) previous topic - next topic
eazy2001x
So I'm taking on an ambient lighting project for my 78 inch Samsung and so far so good. I'm running an UNO.  I'm currently in the middle of the project and was looking into different grabbers for PC based interaction with the Lights.. So I had this thought..
I was considering wrapping my room closer to the molding by the ceiling with WS2812's and was thinking.. Is there a grabber for 5.1 sound.. Something that could light up different parts of the room deepening on which speaker was getting sound at the moment or a level if sound. Also if there was a heavy bass sound it could light the whole room..
Your thoughts?
Eazy
PaulRB
The only way I know that might work would be an msgeq7 chip for each channel of interest. You would need line-level analog audio signals to feed the chips. The Arduino could read the output from the chips and make appropriate colour displays on the strip
eazy2001x
it might be possible to use something to decode dolby from the HDMI cable.. So apparently there is a Pi input board for HDMI to start with..
Input Board Link
and after lookng around i sww that someone was able to interface the uno with the pi over serial. this could be a way to get the 5.1 channel information from the pi over to the uno for starters. then we can look at what to do after the fact?
Input Shield Link
PaulRB
I'm sure a Pi could drive the ws2812 directly. The Arduino seems redundant. I don't know how to get that to work, but including a Pi and an Arduino just seems to be making things more complicated than they need to be.
eazy2001x
Thats not the issue of driving the WS2812B.. its the HDMI input to decode the dolby channels.. that was the only reason i suggested to add the pi.
eazy2001x
maybe this can be used instead directly connected to the uno.
TFP401 HDMI/DVI Decoder to 40-Pin TTL Breakout - Without Touch Link
eazy2001x
Pk, different thought process.. We can get a split HDMI cable and use an output off it to feed this device which already decodes no problem..
HDMI-to-HDMI-Audio-Decoder Link
at that point can we take the channel information and feed 6 pins on the uno to determine the volume output of each channel's RCA and use that to control the WS2812B?
then we can do things like if the sub is loud the LEDS all turn from purple low / blue med / red high.
we could also do things like.. fun shot from channel front lest to rear right chase LEDS from both directions around a square room to the other side. so we can see the travel of the bullet. at that point the sub will be used to determined brightness of the LEDS. and the color could be anything like white or purple..
Just tossing out ideas..
PaulRB
Please learn how to post links properly, like this.
Quote
No, the signals would damage the Arduino. See reply #1.
eazy2001x
PaulRB
It helps by not damaging the Arduino's analog inputs. You cannot connect a line level audio signal to an Arduino analog pin without it being damaged by the negative voltages in the signal. The msgeq7 chip has an input which is designed to accept a line level audio signal. It also contains circuits that measure the volume of the signal in 7 frequency bands.
Qdeathstar
if you just want it to respond to amplitude, the simplest way to do this is with microphones placed near each speaker.....
https://learn.sparkfun.com/tutorials/addressable-rgb-led-music-and-sound-visualizer
A creaking creeping shadow
stiff against the freezing fog
glares at a tickless watch.
Time has failed him -- all things shall pass.
eazy2001x
The chip is a starting point and although the microphone idea is good it's not a clean approach toward this. Which is why the thought process of the hdmi sound decoding came into play
PaulRB
Well, you have a route to one potential solution. The hdmi decoder box you gave the link to, connected to an Arduino via some number up to 6 X msgeq7 chips.
And you have another potential but less resolved solution based around an RPi. You should post on the RPi forums for help on that one. It has the potential to be a simpler solution overall, avoiding the analog domain entirely. I don't think an Arduino will be necessary for that solution. It seems a little pointless to add a 16MHz processor to a 1GHz+ processor!
eazy2001x
Hmm.. You bring up good points.. The thing in my current setup is that I have an output on my receiver that I can use right now.. I could plug the output directly to the decoder box. Then get a bread board and wire 6 rca connectors to it and order 6 of those chips then report back at that point. Can you give me an idea on how to wire the chip to the arduino please.
Thanks for all the help
Also for now I'll wire in 40 ws2812b,'s just to get things started, I would prefer to stick to the arduino for now and if later on I want to to switch over I'll do so but so far I've been working on this board and want to learn more before just giving up and switching to a new platform.  I'll also go back and update the links..
PaulRB
Just Google "Arduino msgeq7". There are loads of examples. Just start with one chip and get that working. Then add more. You may find you don't need 6. 3 or 4 may give you the effects you want. You can combine 2 channels with a couple of resistors, for example the rear two or the centre and sub channels.
Multiple chips can share the same Arduino pins for reset and strobe but will obviously need separate analog inputs.
Tip 1: use a Nano 3. It can plug into your breadboard and has 2 extra analog pins.
Tip 2: the pins on most 3.5mm headphone sockets are not long enough to reliably connect to a breadboard, you need to make or buy an adaptor.
