Author Topic: EEprom storage using writeAnything.h  (Read 904 times)
South East USA
mySensVals   will be numbers anywhere from 100 to 2000
Does the Uno have enough eeprom to store this many settings?
thanks.
struct config_settings
    int mySensVals[12];  //# of pulses in 2-12 cups
    boolean Enable_Audio;  //whether the user wants sound
    boolean Enable_Piezo;  //whether the user wants a knock sensor
    boolean Enable_PhotoCell;  //whether the user wants to use the photocell
} MySettings;
//...set up values to save.
    EEPROM_writeAnything(0, MySettings);  //save the settings
Left Coast, CA (USA)
Measurement changes behavior
I count 27 bytes of storage needed to store that structure into eeprom. As the Uno has a 1,000 byte eeprom it should fit rather nicely, if not lonely with all the extra eeprom space avalible.  smiley-wink
Lefty
South East USA
Thanks! (that was quick).  I'll reread the ref section on sizes, an integer must be only 2 bytes, and a boolean 1, to only add up to 27...
South East USA
Yeah, I just read the size of bolleans and integers.  strange a boolean only holds true or false, in 1 byte, and and integer at 2 bytes can hold a huge number.  I thought it would have been a lot more bytes than that.  I should be okay with all the settings I can think of changing!
UK
Online Online
The smallest addressible item on the AVR is a byte.
If you are really pushed for space (it doesn't look like you are!), you can use structs with bit-fields defined in them for boolean flags.
struct {
unsigned flag0:1; // defines eight, one bit fields.
unsigned flag1:1;
unsigned flag2:1;
unsigned flag3:1;
unsigned flag4:1;
unsigned flag5:1;
unsigned flag6:1;
unsigned flag7:1;};
South East USA
struct config_settings {
    int mySensVals[13];  //# of pulses in 2-12 cups
    int motor_delay;     //change the distance the platform travels
    boolean Enable_Photocell;  //whether the user wants to use the photocell to turn on the cabinet lighting
    int Photocell_Level;  //threshold for light/darkness
} MySettings;
void LoadSettings(){
  EEPROM_readAnything(0, MySettings);   //load the settings
void SaveSettings(){
  sendMessage("Settings saved!");
...so I think I'm using 33 bytes of EEPROM to save settings.
Now I have other settings I want to save/load in reference to time, since I've added an RTC module.
Can I save other settings to another part of the EEPROM like this:
    int CurrentYear;    //for keeping track of what year it is
    int CupsTotal;    //lifetime total
    int CupsMonth;    //cups drank this month
    int CusYear;        //cups drank this year
    int CupsLast;    //last cup drank
} TimeData;
  EEPROM_readAnything(34, TimeData);   //load the settings
  EEPROM_writeAnything(34, TimeData);  //save the settings
Seattle, WA USA
Seattle, WA USA
Yes, and no. You have the right idea, and address, but this:
} TimeData;
won't work, because you have already defined a struct called config_settings, so you can't define another struct with the same name.
CusYear? No p?
South East USA
CusYear? No p?
Ok, maybe it'd be better with a p.
 smiley-red
Thanks, I didn't think about the first part of that struct, since I never use the name 'config_settings', I thought it was just part of the code that made the whole thing work.  So it can be anything?
Seattle, WA USA
Seattle, WA USA
Well, there are a few reserved keywords that it CAN'T be, but everything else is what it CAN be.
