Loading...
Pages: [1]   Go Down
Author Topic: correct baud-rate for avrdude to programme ATMEGA8-16PU  (Read 1379 times)
Pakistan
Offline Offline
Newbie
just a beginer
View Profile
WWW
Hi Arduino,
I am lost in loading bootloader for Arduino Single Sided on ATMEGA8-16PU.
Here is my problem.
1- I made the Arduino Single Sided V3 from this page http://www.arduino.cc/en/Main/ArduinoBoardSerialSingleSided3.
2- Placed ATMEGA8-16PU in the board and attached it to the Parallel Programmer described here http://www.arduino.cc/en/Hacking/ParallelProgrammer and attached external 9V battery.
3- Accessed the controller using avrdude using command line and it returned correct signature 0x1e9307.
4- I executed this command "avrdude -p atmega8 -c dapa -P lpt1 -U lock:w:0xff:m" it worked well. Everything was fine till this point and controller returning correct signature.
5- Then this  "avrdude -p atmega8 -c dapa -P lpt1 -U hfuse:w:0xca:m -U lfuse:w:0xdf:m" and suddenly after execution of this command controller was returning wrong signature 0x000012.
What is wrong? i cannot go further? why it is returning the wrong signature.
But i noticed something odd, controller was not returning 0xffffff it means it is not bricked, its alive and hence returning signature whatever it is.
May be the default baud-rate of programmer is not matching anymore with the baud-rate change in controller for different clock source.
What should i do ?
Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
Make absolutely certain the crystal and capacitor connections are good.
Quote
Was "0x000012" the signature value returned?  Or was the value "0x000102"?
Logged
Pages: [1]   Go Up
Print
Jump to:
