Topic: ESP8622-ESP01 using FTDI + Arduino IDE (Read 413 times) previous topic - next topic
mkane
Apr 20, 2018, 07:09 pm Last Edit: Apr 20, 2018, 07:10 pm by mkane
Hey Everyone,
First thank you for any help you may give me.
I am trying to communicate an ESP862201 with the Arduino IDE. I have followed instruction on adding the ESP8622 to the board manager inside of the IDE and that seems ok.
The problem is when I try to upload or communicate with the esp8622. I am using the FTDI as a bridge to upload sketch files onto the 8622.
When using the serial monitor I see ............ on 115200 Baud but weird character on any other channel. However when sending the AT command I never get a response no matter which channel.
The other problem is when uploading the sketch file I see
warning: espcomm_sync failed
error: espcomm_open failed
error: espcomm_upload_mem failed
I do see blue light on my esp8622 and both are powered on. I have the FTDI powering the esp8622.
I know the pins are hooked up right however the dividers I am not sure are correct.
PaulRB
Quote
I assume you mean esp8266? The ftdi cannot provide enough current for the esp. You need a separate regulator of some kind. Perhaps something based on ams1117.
mkane
Yes, 8266 sorry!
I have switched out the FTDI, I am not sure what it is. (Sorry, software guy here). I will attach a pic. I am able to now get the AT commands working with this new power source. I can join my WiFi and obtain an IP address.
Do I need to put the ESP 8266 into flash mode for this to work?
mkane
Now it gets to 95% and stops. It did upload 100% a few times (put it in programming mode) but now.i get
Arduino: 1.8.5 (Mac OS X), Board: "Generic ESP8266 Module, 80 MHz, ck, 26 MHz, 40MHz, QIO, 512K (no SPIFFS), 2, v2 Lower Memory, Serial, None, Only Sketch, 115200"
Archiving built core (caching) in: /var/folders/kv/f7drssbs0bv4w17ycwcs5d6r0000gp/T/arduino_cache_695195/core/core_esp8266_esp8266_generic_CpuFrequency_80,ResetMethod_ck,CrystalFreq_26,FlashFreq_40,FlashMode_qio,FlashSize_512K0,led_2,LwIPVariant_v2mss536,Debug_Serial,DebugLevel_None____,FlashErase_none,UploadSpeed_115200_e5ab0ff892b614113ea46e0d82f05a51.a
Sketch uses 253464 bytes (50%) of program storage space. Maximum is 499696 bytes.
Global variables use 32812 bytes (40%) of dynamic memory, leaving 49108 bytes for local variables. Maximum is 81920 bytes.
warning: espcomm_send_command: wrong direction/command: 0x01 0x03, expected 0x01 0x08
Uploading 257616 bytes from /var/folders/kv/f7drssbs0bv4w17ycwcs5d6r0000gp/T/arduino_build_766272/web_server.ino.bin to flash at 0x00000000
................................................................................ [ 31% ]
................................................................................ [ 63% ]
................................................................................ [ 95% ]
...........warning: espcomm_send_command: didn't receive command response
warning: espcomm_send_command(FLASH_DOWNLOAD_DATA) failed
warning: espcomm_send_command: wrong direction/command: 0x01 0x03, expected 0x01 0x04
option enabled in File -> Preferences.
mkane
OK progress. I am getting 100% but nothing shows up in the serial monitor. Was this successful?
Sketch uses 275360 bytes (55%) of program storage space. Maximum is 499696 bytes.
Global variables use 33684 bytes (41%) of dynamic memory, leaving 48236 bytes for local variables. Maximum is 81920 bytes.
Uploading 279504 bytes from /var/folders/kv/f7drssbs0bv4w17ycwcs5d6r0000gp/T/arduino_build_766272/web_server.ino.bin to flash at 0x00000000
................................................................................ [ 29% ]
................................................................................ [ 58% ]
................................................................................ [ 87% ]
.................................                                                [ 100% ]
ieee488
You will get inconsistent results if you don't provide a good 3.3V supply for the ESP8266.
Do that !
PaulRB
#6
Apr 21, 2018, 07:54 am Last Edit: Apr 21, 2018, 08:09 am by PaulRB
Quote
What sketch did you upload? Does the sketch send anything to serial monitor?
Totally unhelpful picture, btw.
If you want to learn to build projects with esp, as a beginner, get an esp based dev board. I recommend Wemos mini.
I have had good results with one of those ultra-cheap "programmers" - https://www.ebay.com/itm/142082226373
You'll need to wire a button between gpio0 and GND and press it until the upload starts (read the following links to know why this does not work for everyone).
Info about programming the ESP-01
https://www.allaboutcircuits.com/projects/breadboard-and-program-an-esp-01-circuit-with-the-arduino-ide/
https://www.allaboutcircuits.com/projects/flashing-the-ESP-01-firmware-to-SDK-v2.0.0-is-easier-now/
To work with this module in a breadboard is probably a good idea to get a cheap breadboard adapter like this one: https://www.ebay.com/itm/232577675252
But I agree with PaulRB, the ESP-01 is not the best module to start playing with the 8266, I suggest you get one that have an integrated USB adapter.
You never learn anything by doing it right.
