Topic: Problems with tmp100 i2c temp sensor (Read 5066 times) previous topic - next topic
priya
Hello folks,
I'm trying to get tmp100 working with arduino fio. Here is the code
#define address 0x94
//address of the temperature sensor
#define delayC 1000
//delay count in ms
#define baudrate 9600
//baudrate for communication
#include <Wire.h>
  Wire.begin();
  Serial.begin(baudrate);
  Serial.print("temperature in Celsius: ");
  //let's signal we're about to do something
  int temperature;
  //temperature in a byte
  Wire.beginTransmission(address);
  //start the transmission
  Wire.send(0x00);
  Wire.requestFrom(address, 1);
  if (Wire.available()) {
    temperature = Wire.receive();
    Serial.println(temperature);
    Serial.println("---");
  Wire.endTransmission();
  //end the transmission
  delay(delayC);
When i run this code, i get "Temperature in celsius: ----" on serial monitor. I guess the device tmp100 is not giving any data to arduino over i2c. I checked address of tmp100 again and temperature register too. Both look fine. I don't understand what the problem is?
Please help!
WillR
Any chance you could post a link to the data sheet -- preferably from the manufacturers site? The one that shows the registers and recommended code is helpful. Who made it and what is the full part number.
Did you look for a library or working program for that device??
Just another Hacker
priya
Here's the link to manufacturers datasheet:
focus.ti.com/lit/ds/symlink/tmp100.pdf
The register is 0x00.
Thank you.
robtillaart
have you checked the forum yet ? - http://arduino.cc/forum/index.php/topic,10955.0.html
Rob
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
priya
Thanks Rob. But i had checked that link already. I have tried some other variations in program also. Few libraries like I2Cmaster etc too!
Now i guess..the problem is in hardware, not the code. I have redesigned the tmp100 board. I'll get it manufactured in couple of days time and try out everything on it again.
Fingers crossed!
Priya.
wayneft
Problem is with your code.  You need a Wire.endTransmission after your Wire.send and you need to delete the Wire.endTransmission at the end of the sketch.
I2C GPS Shield
Checkout my Open Source GPS Tracker on Kickstarter
avrMikroC
I have found an article about Arduino + TMP100 temperature sensor with Nokia 3310 LCD display here: http://avr.gamfrobotics.hu/?p=141
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
