Loading...
Pages: [1] 2   Go Down
Author Topic: Byte mirroring  (Read 984 times)
Brebu
Offline Offline
Full Member
New to Arduino
View Profile
WWW
Is there a function that can mirror a byte?
If i have 11111100 i want to obtain 00111111
i will try ~
« Last Edit: March 04, 2011, 11:26:41 am by gvi70000 » Logged
Brebu
Offline Offline
Full Member
New to Arduino
View Profile
WWW
what i have so far is
Code:
uint8_t S65Display::ReverseByteBits(uint8_t value)
            uint8_t ret = 0;
            for (int i = 0; i < 8; i++)
                if ((value & (uint8_t)(1 << i)) != 0) ret += (uint8_t)(1 << (7 - i));
            return ret;
is there a quicker way?
Logged
Ontario
Offline Offline
God Member
View Profile
Shifts by more than one bit are slow on Arduino.  You should be able to do it with a total of 16.
If you are in a real hurry, use a lookup table in PROGMEM.
Code:
reverse(uint8_t in)
  uint8_t out;
  char i;
  out = 0;
  for (i = 0; i < 8; i++) {
      out <<= 1;
      if (in & 1)
        out |= 1;
      in >>= 1;
  return out;
less compact, but faster
Code:
reverse(uint8_t in)
  uint8_t out;
  out = 0;
  if (in & 0x01) out |= 0x80;
  if (in & 0x02) out |= 0x40;
  if (in & 0x04) out |= 0x20;
  if (in & 0x08) out |= 0x10;
  if (in & 0x10) out |= 0x08;
  if (in & 0x20) out |= 0x04;
  if (in & 0x40) out |= 0x02;
  if (in & 0x80) out |= 0x01;
  return(out);
« Last Edit: March 04, 2011, 12:20:50 pm by gardner » Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
There is no reason to perform the if test. The statement will write either a 0 or a 1 to the specified bit. It will be faster if you simply write the 0 than to test that the value would be 0 in order to avoid writing the 0.
Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
this is a job for - http://www.amazon.com/Hackers-Delight-Henry-S-Warren/dp/0201914654/ref=sr_1_1?ie=UTF8&s=books&qid=1299262192&sr=1-1
I have the book on my wishlist but there is allways this site for bithacks: - http://graphics.stanford.edu/~seander/bithacks.html#BitReverseObvious
(tested positive on Arduino)
Code:
 b = ((b * 0x0802LU & 0x22110LU) | (b * 0x8020LU & 0x88440LU)) * 0x10101LU >> 16;
or
b = (b * 0x0202020202ULL & 0x010884422010ULL) % 1023;  // 64 bit
there are more " bit beauties" there.
« Last Edit: March 04, 2011, 01:29:47 pm by robtillaart » Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
I recall several decades ago needing to 'flip' a byte in turbo pascal, so I wrote a function. It was ugly but it did work. I would think a nice class library function that would 'flip' any variable passed to it, byte, int, long, would be a neat function to have in one's toolbag? Any of you software gurus up to the challenge?
Lefty
Logged
UK
Offline Offline
Faraday Member
Gorm deficient
View Profile
I've worked on architectures (DSPs mostly) that do it in hardware because it is so useful for FFTs
Logged
Per Arduino ad Astra
Offline Offline
Brattain Member
View Profile
Is that the so called barrel shifter function or hardware ?
Logged
UK
Offline Offline
Faraday Member
Gorm deficient
View Profile
No, that's a one cycle shifter - these were often simply switchable bus lines
Logged
Offline Offline
Brattain Member
View Profile
Wow, that would be pretty fast, but I guess that's the reason/justification for such specialized hardware features frequently used in Dsp applications
Logged
Netherlands
Offline Offline
Tesla Member
View Profile
@groove :
Hardware: 74HC595  (all lines crossed)   74HC165     shiftOut byte shiftIn reverse  is that possible (no IC at hand)
@lefty
According to - http://graphics.stanford.edu/~seander/bithacks.html#ReverseParallel
this should be it:  (not tested)
Code:
unsigned int s = sizeof(v) * CHAR_BIT;   // bit size; must be power of 2
unsigned int mask = ~0;
while ((s >>= 1) > 0)
  mask ^= (mask << s);
  v = ((v >> s) & mask) | ((v << s) & ~mask);
Logged
Rob Tillaart
Phoenix, Arizona USA
Offline Offline
Faraday Member
Where's the beer?
View Profile
WWW
Code:
or
Thanks for posting that - I was pretty certain there had to be a way to do it algorithmically without needing a loop construct, and that it had to be something already invented (if not in the AVR libc!); something that always gets me is the vast amount of time we spend constantly re-inventing the wheel, thinking that somehow we'll be able to do it better (or that our technique is first), seemingly forgetting that computing has a fairly long history behind it.
Not to mention the fact that if your CPU uses "fewer bits" than your PC, likely someone in the past 40-odd years (or greater if you want to include the pre-personal computing era) has already run into the issue, and a solution already exists; the only trouble is finding it, which is why knowing that link you posted (which I've run across in the past), as well as that book (which I haven't, but is going on my "to purchase" list - though I have too many books as it is!) - are both items (among many) that people in this field should be aware of...
smiley
Logged
Netherlands
Offline Offline
Tesla Member
View Profile
Quote
many interesting algorithms were invented/designed in the 60ies - most memorable Quicksort in 1960(!)
Logged
Rob Tillaart
Offline Offline
Brattain Member
View Profile
@groove :
@lefty
Code:
I tried it but got a compiler error " CHAR_BIT not declared in scope" ?
Is that just how many bits in a character for the machine it's running on, 8 for AVR?
« Last Edit: March 04, 2011, 02:04:35 pm by retrolefty » Logged
Brebu
Offline Offline
Full Member
New to Arduino
View Profile
WWW
Thank you all for the replays, i did learn something from them
The link provided by robtillaart i added to favorites  smiley-money
This post is about using an array to draw chars on LCD's. i'm using LS020, LH88 and L2F50
the arrays looks like this, each line represents a character 8x8 bits
Code:
const prog_uint8_t font[] =
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // 0x20
  0x30,0x78,0x78,0x30,0x30,0x00,0x30,0x00, // 0x21
  0x6C,0x6C,0x6C,0x00,0x00,0x00,0x00,0x00, // 0x22
  0x6C,0x6C,0xFE,0x6C,0xFE,0x6C,0x6C,0x00, // 0x23
  0x30,0x7C,0xC0,0x78,0x0C,0xF8,0x30,0x00, // 0x24
  0x00,0xC6,0xCC,0x18,0x30,0x66,0xC6,0x00, // 0x25
  0x38,0x6C,0x38,0x76,0xDC,0xCC,0x76,0x00, // 0x26
  0x60,0x60,0xC0,0x00,0x00,0x00,0x00,0x00, // 0x27
  0x18,0x30,0x60,0x60,0x60,0x30,0x18,0x00, // 0x28
  0x60,0x30,0x18,0x18,0x18,0x30,0x60,0x00, // 0x29
  0x00,0x66,0x3C,0xFF,0x3C,0x66,0x00,0x00, // 0x2A
  0x00,0x30,0x30,0xFC,0x30,0x30,0x00,0x00, // 0x2B
The L2F50 has a different way of reading bits
"T" char for example is rotated with 90deg and mirrored, the last part i resolve it with your help
 now i have to rotate so that "|-" (this is an approximation) will become "T"
Any idea how to start?
Logged
Pages: [1] 2   Go Up
Print
Jump to:
