Loading...
Pages: 1 [2]   Go Down
Author Topic: Byte mirroring  (Read 987 times)
Brebu
Offline Offline
Full Member
New to Arduino
View Profile
WWW
this is the function to draw the char
Code:
uint8_t S65Display::drawChar(uint8_t x, uint8_t y, char c, uint8_t size, uint16_t color, uint16_t bg_color)
uint8_t ret;
uint8_t data, mask;
uint8_t i, j, width, height;
const prog_uint8_t *ptr;
i  = (uint8_t)c;
ptr= &font[(i-FONT_START)*(8*FONT_HEIGHT/8)];
width  = FONT_WIDTH;
height = FONT_HEIGHT;
if(size <= 1)
ret = x+width;
if(ret > S65_WIDTH) {return S65_WIDTH+1;}
setArea(x, y, (x+width-1), (y+height-1));
s65_drawStart();
#ifdef S65_L2F50
for(; height!=0; height--)
data = (pgm_read_byte(ptr) * 0x0202020202ULL & 0x010884422010ULL) % 1023;ptr+=1;//mirror bits
for(mask=(1<<(width-1)); mask!=0; mask>>=1)
if(data & mask)
s65_draw(color);
s65_draw(bg_color);
#else
data = pgm_read_byte(ptr); ptr+=1;
if(data & mask)
s65_draw(color);
s65_draw(bg_color);
#endif
s65_drawStop();
ret = x+(width*size);
s65_setArea(x, y, (x+(width*size)-1), (y+(height*size)-1));
s65_drawStart();
for(i=size; i!=0; i--)
if(data & mask)
for(j=size; j!=0; j--)
s65_draw(color);
s65_draw(bg_color);
s65_drawStop();
return ret;
Logged
Phoenix, Arizona USA
Offline Offline
Faraday Member
Where's the beer?
View Profile
WWW
Quote
likely someone in the past 40-odd years (or greater if you want to include the pre-personal computing era) has already run into the issue, and a solution already exists;
many interesting algorithms were invented/designed in the 60ies - most memorable Quicksort in 1960(!)
Definitely - some of the best stuff in computing, both hardware and software, was developed during that decade; many of the things we think of as "advanced" in a PC were actually available on mainframes of the era. The advance is in the miniaturization, and comoditization of these developments (which certainly shouldn't be discounted).
 smiley
Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
@lefty
CHAR-bit is #bits in a char so it must be 8. eg  #define CHAR_BIT 8
(tested for the first 100 values not tested for other datatypes
Code:
  Serial.println("I am Arduino");
  for (unsigned int i=0; i < 65535; i++)
    unsigned int v = i;
    Serial.print(v, BIN);
    Serial.print(' ');
    unsigned int s = sizeof(v) * 8;   // bits/byte; must be power of 2
    unsigned int mask = ~0;
    while ((s >>= 1) > 0)
      mask ^= (mask << s);
      v = ((v >> s) & mask) | ((v << s) & ~mask);
    Serial.println(v, BIN);
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Netherlands
Offline Offline
Tesla Member
View Profile
@Cr0sh
Quote
Where's the beer?
http://maps.google.nl/maps?f=q&source=s_q&hl=nl&geocode=&q=beer+England&aq=&sll=52.469397,5.509644&sspn=3.681428,13.392334&ie=UTF8&hq=&hnear=Beer,+Seaton,+Verenigd+Koninkrijk&ll=50.709504,-3.094368&spn=0.119576,0.41851&z=12
smiley
Logged
Rob Tillaart
UK
Offline Offline
Faraday Member
Gorm deficient
View Profile
A very lovely village, but a long way from Sandwich
Logged
Per Arduino ad Astra
Ontario
Offline Offline
God Member
View Profile
Code:
b = ((b * 0x0802LU & 0x22110LU) | (b * 0x8020LU & 0x88440LU)) * 0x10101LU >> 16;
This requires 3 long multiplications plus some 32-bit logical ops. On AVR I would stand either of my solutions up against this.  The optimal solution is likely a lookup table which would do the job in something like 4 instructions.
Logged
Netherlands
Offline Offline
Tesla Member
View Profile
Quote
You are probably right, optimal allways depends on context, that might be size or speed or something in between.
- a lookuptable would take 256 bytes and addressing it is (beginaddress + index) so that is optimized for speed. For the Arduino 256 bytes is 13% of the RAM (or store it in prog_mem). Which version is optimized for size I don't know, I think the loop enrolled version is a good compromise of speed and size.
Logged
Rob Tillaart
Brebu
Offline Offline
Full Member
New to Arduino
View Profile
WWW
Once again thank you all for the help provided
I have found an easier way to resolve my problem by generating an rotated + mirrored font file
this is a great toll
http://www.min.at/prinz/software/pixelfont/
Logged
Netherlands
Offline Offline
Tesla Member
View Profile
A small test for different methods, (IDE 21, Atmel 328, windows 7)
Code:
  unsigned long start = micros();
  for (int i=0; i<256; i++)
    volatile uint8_t b = i;
  Serial.println(micros() - start);
  while (1);
Time: 6408  usec (512 flips) => 12.5 usec =  200 clockcycles / flip
Code:
    b = (b * 0x0202020202ULL & 0x010884422010ULL) % 1023;
  while (1);
Time: 151804 usec (512 flips)  => 296.5 usec per flip = 4744 clockcycles / flip
Although the formula is shorter the use of ULL datatype in combination with modulo makes this far bigger and slower
Code:
// big lookup table
uint8_t x[256] = { 0,128,64,192,32,160,96,224,16,144,80,208,48,176,112,240,8,136,72,200,40,168,104,232,24,152,88,216,56,184,120,248,4,132,68,196,36,164,100,228,20,148,84,212,52,180,116,244,12,140,76,204,44,172,108,236,28,156,92,220,60,188,124,252,2,130,66,194,34,162,98,226,18,146,82,210,50,178,114,242,10,138,74,202,42,170,106,234,26,154,90,218,58,186,122,250,6,134,70,198,38,166,102,230,22,150,86,214,54,182,118,246,14,142,78,206,46,174,110,238,30,158,94,222,62,190,126,254,1,129,65,193,33,161,97,225,17,145,81,209,49,177,113,241,9,137,73,201,41,169,105,233,25,153,89,217,57,185,121,249,5,133,69,197,37,165,101,229,21,149,85,213,53,181,117,245,13,141,77,205,45,173,109,237,29,157,93,221,61,189,125,253,3,131,67,195,35,163,99,227,19,147,83,211,51,179,115,243,11,139,75,203,43,171,107,235,27,155,91,219,59,187,123,251,7,135,71,199,39,167,103,231,23,151,87,215,55,183,119,247,15,143,79,207,47,175,111,239,31,159,95,223,63,191,127,255};
    b = x[b];
    b = x[b];
  while (1);
Time:  436 usec (512 flips)  => 0.85 usec per flip = 13.6 clockcycles / flip
Really fast as expected, but not the smallest footprint so far
Code:
// small lookup table - 4bit level iso 8 bit
// notice the pattern between the first 8 and the latter 8 in the table
uint8_t xx[16] = { 0,8,4,12,  2,10,6,14,  1,9,5,13,  3,11,7,15};
    b = xx[b & 0x0F] << 4 | xx[b>>4];
  while (1);
Time:  1468 usec (512 flips)  => 2.86 usec per flip = 46 clockcycles / flip
Three times slower than the fastest, but still second fastest.
With 2624 the smallest in footprint so far.
Code:
  for (int j=0; j<256; j++)
    volatile uint8_t value = j;
    volatile uint8_t ret = 0;
    for (int i = 0; i < 8; i++)
      if ((value & (uint8_t)(1 << i)) != 0) ret += (uint8_t)(1 << (7 - i));
    value = ret;
  while (1);
Time:  14008 usec (512 flips)  => 27.4 usec per flip = 438 clockcycles / flip
Good footprint, but relative slow.
Code:
    volatile uint8_t in = j;
    uint8_t out = 0;
    if (in & 0x01) out |= 0x80;
    if (in & 0x02) out |= 0x40;
    if (in & 0x04) out |= 0x20;
    if (in & 0x08) out |= 0x10;
    if (in & 0x10) out |= 0x08;
    if (in & 0x20) out |= 0x04;
    if (in & 0x40) out |= 0x02;
    if (in & 0x80) out |= 0x01;
    in = out;
    out = 0;
  while (1);
Time:  996 usec (512 flips)  => 1.95 usec per flip = 32 clockcycles / flip
Smallest footprint, second in performance
So the 256 byte lookup table is fastest but the enrolled loop is very fast too and has a 200byte smaller footprint.
All disclaimers apply smiley
Logged
Rob Tillaart
Ontario
Offline Offline
God Member
View Profile
You need a control in which you calculate the computational complexity of the loop overhead and then factor that out of the other measurements.  Your figure of 13.6 clockcycles/flip for the table lookup includes the overhead of incrementing and comparing the loop variable, the conditional branch at the top and the branch back from the bottom.  That's, what? 4 instructions -- comparable to the loop contents.
And the table lookup should be to progmem -- making it at least one instruction longer.  The way you have it, it takes 256 bytes of ROM *and* another 256 bytes of RAM.  It is probably the worst approach since RAM is so scarce.
Anyhow, nice work and thank you for backing up my claims!
Logged
Netherlands
Offline Offline
Tesla Member
View Profile
You're welcome, was kinda fun
You are 100% right that these tests are only indicative as overhead is included, but that said, they are indicative enough  smiley
Logged
Rob Tillaart
Pages: 1 [2]   Go Up
Print
Jump to:
