« Reply #15 on: March 22, 2011, 10:31:10 am » |
I had to change the Ethernet.cpp file b/c I noticed gateway was being set as IP then changing last octet only and subnet was statically set here as well. Before: //uint8_t gateway[4]; //gateway[0] = ip[0]; //gateway[1] = ip[1]; //gateway[2] = ip[2]; //gateway[3] = 1; //uint8_t subnet[] = { //255, 255, 255, 0 }; After: #include "w5100.h" #include "Ethernet.h"
uint8_t EthernetClass::_state[MAX_SOCK_NUM] = { 0, 0, 0, 0 }; uint16_t EthernetClass::_server_port[MAX_SOCK_NUM] = { 0, 0, 0, 0 };
void EthernetClass::begin(uint8_t *mac, uint8_t *ip, uint8_t *gateway) { begin(mac, ip, gateway); }
void EthernetClass::begin(uint8_t *mac, uint8_t *ip, uint8_t *gateway, uint8_t *subnet) { W5100.init(); W5100.setMACAddress(mac); W5100.setIPAddress(ip); W5100.setGatewayIp(gateway); W5100.setSubnetMask(subnet); }
EthernetClass Ethernet;
Netherlands
« Reply #16 on: March 22, 2011, 01:48:01 pm » |
@Jo3ri, Fun an Arduino "basic" sketch
Hamme, Belgium
« Reply #17 on: March 23, 2011, 02:58:59 am » |
@robtillaart I know  But it really helps to write down this kinds of things. Otherwise I get lost in my own coding
« Reply #18 on: March 23, 2011, 01:04:51 pm » |
Update: 1st through 3rd IP octet is not saving correctly. Working on a fix.
« Last Edit: March 23, 2011, 02:17:31 pm by techadmin »
Hamme, Belgium
« Reply #19 on: March 23, 2011, 03:02:34 pm » |
Meanwhile I found out your working on a different Arduino version (mine is 0.22) also I have the new Arduino Ethernet Shield. But the Idea remains the same.
FYI: I thanks to your sketch, I managed to use EEPROM for storing mac, ip, gw, sub and type (static, dhcp or unknown) and showing this info in the webpage.
The sketch starts with setting the pre-sets the first time and writes a knowing bit. The next time it runs, the sketch doesn't use pre-sets, but reads EEPROM: when type is stored as static, it takes static otherwise it takes dhcp.
Now I need to work on the GET forms in html. I haven't found out how to do that yet, but I'll get there.
« Reply #20 on: March 23, 2011, 03:24:42 pm » |
I am using 022? Sounds like good progress.
Hamme, Belgium
« Reply #21 on: March 23, 2011, 04:46:29 pm » |
Ah, then it must be a different Ethernet Shield.  Now you're sending HTML in a different way then I do, I use: Client.print("<HTML><body>some text or other HTML code</body></HTML>"); Now I was hoping to get help out of your sketch for the forms part, but I can't  I'll have to figure it out myself
« Reply #22 on: March 23, 2011, 05:24:55 pm » |
I started with client.print as well and used all of the SRAM doing so.
My sketch is using the Flash library which easily puts all that html into program memory, dramatically improving performance.
Hamme, Belgium
« Reply #23 on: March 24, 2011, 03:03:01 am » |
Aha, I See. Well I found a way to do the same, but I'm using the avr/pgmspace.h library. This way I can put every thing in The Flash Memory with PROGMEM and I let it flow through a buffer of let's say 100 bytes (SRAM).
This should mean I could use your HTML code for the forms. Could you filter them out and post them? Especially t he part where you get the info out of the forms.
Thanks.
« Reply #24 on: March 24, 2011, 10:49:02 am » |
Here is the basic form, you will see from my code that these are simply wrapped in client << F(" ") << "\n";
You can accomplish the same with Progmem, not sure which is more memory efficient. I struggled freeing memory for a while and this worked best for me, at least it seemed the easier method. I will be interested to see your take on this as well. When the form is posted, a get string is created such as this: http://172.31.1.50/?i1=172&i2=31&i3=4&i4=50&s1=255&s2=255&s3=255&s4=0&g1=172&g2=31&g3=1&g4=1&END=ENDThat string is saved to inString initially then to stringOne: String stringOne = inString; For substring processing I am using indexOf to find the number between all of the & and = symbols. ////////////// CHANGE IP ADDRESS FORM /////////////////////////////////////////////////////
<BR><BR><B>Change IP Address:</B>
<form name=\"changeipaddress\" action=\"\" method=\"get\"> <TABLE width=\"325\"> <tr> <td>IP Address:</td> <td><input type=\"text\" size=\"3\" maxlength=\"3\" name=\"i1\" value=\"172\"></td> <td><input type=\"text\" size=\"3\" maxlength=\"3\" name=\"i2\" value=\"31\"></td> <td><input type=\"text\" size=\"3\" maxlength=\"3\" name=\"i3\" value=\"1\"></td> <td><input type=\"text\" size=\"3\" maxlength=\"3\" name=\"i4\" value=\"50\"></td> </tr>
<tr> <td>Subnet Mask:</td> <td><input type=\"text\" size=\"3\" maxlength=\"3\" name=\"s1\" value=\"255\"></td> <td><input type=\"text\" size=\"3\" maxlength=\"3\" name=\"s2\" value=\"255\"></td> <td><input type=\"text\" size=\"3\" maxlength=\"3\" name=\"s3\" value=\"255\"></td> <td><input type=\"text\" size=\"3\" maxlength=\"3\" name=\"s4\" value=\"0\"></td> </tr>
<tr> <td>Gateway:</td> <td><input type=\"text\" size=\"3\" maxlength=\"3\" name=\"g1\" value=\"172\"></td> <td><input type=\"text\" size=\"3\" maxlength=\"3\" name=\"g2\" value=\"31\"></td> <td><input type=\"text\" size=\"3\" maxlength=\"3\" name=\"g3\" value=\"1\"></td> <td><input type=\"text\" size=\"3\" maxlength=\"3\" name=\"g4\" value=\"1\"></td> <td><input type=\"hidden\" size=\"3\" maxlength=\"3\" name=\"END\" value=\"END\"></td> </tr> //notice the hidden form element placed in order to create a final "&" character in the get string
<tr> <td align=\"center\" colspan=\"5\"><input type=\"submit\" value=\"Update Network Configuration\"></td> </tr>
<tr> <td align=\"center\" colspan=\"5\">*After changing IP address<BR>change url in browser</td> </tr> </TABLE> </form>
« Reply #25 on: March 24, 2011, 11:21:50 am » |
For any followers, this project is in collaboration with this one: http://arduino.cc/forum/index.php/topic,55044.0.htmlIf your sending your project to someone with no development experience, maybe your dad, or a potential client you've built a prototype for, or your using your Arduino in multiple locations (and not all have DHCP servers), then you just want to be able use the product out of the box on a network, like a home router, plug and play, this will be the solution.
« Reply #26 on: March 27, 2011, 09:19:39 pm » |
The revised web form code is now working properly (for me at least), see attachments.
« Reply #27 on: April 06, 2011, 06:48:53 am » |
To bad it doesn't work on my Uno and latest ethershield (microSD reader). Can't ping the IP adres. If I Disabling these settings I can ping the arduino but can't access the webpages: //EEPROM address to array // byte mac[6] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; // byte ip[4] = { ipAaddress_READ, ipBaddress_READ, ipCaddress_READ, ipDaddress_READ }; // byte gateway[4] = { gwAaddress_READ, gwBaddress_READ, gwCaddress_READ, gwDaddress_READ }; // byte subnet[4] = { subnetAaddress_READ, subnetBaddress_READ, subnetCaddress_READ, subnetDaddress_READ };
Netherlands
« Reply #28 on: April 06, 2011, 06:55:00 am » |
byte mac[6] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; Do you have multiple Arduino's with the same MAC address? if so change them asap as they should be unique, just a thought.
« Reply #29 on: April 06, 2011, 07:21:37 am » |
byte mac[6] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; Do you have multiple Arduino's with the same MAC address? if so change them asap as they should be unique, just a thought. Sorry No just one.  I found out that the program always jumps to void mkmethernetRESET(). Because I haven't set a new IP address the EEprom values are wrong. I forced the program to jump to void mkmethernetDEFAULTS(). Now I get only a blank page and I can ping the Arduino.
