Topic: issue while installing arduino-connector on upsquare (Read 964 times) previous topic - next topic
MandipJ
While installing arduino-connector through https://create.arduino.cc/getting-started/intel-platforms. Getting:
We were not able to establish a connection between the Arduino Create and your Intel®-based Platform. Make sure your Platform is correctly connected to Internet and you have filled out the Proxy Settings if you are behind Proxy.
I have properly filled proxy and other detail but still getting the same problem.
Also tried to install directly on upsquared but getting below issue:
Generate private key
Generate csr
Request certificate
2018/04/24 05:09:13 requestCert - POST https://api2.arduino.cc/devices/v1/********:8bef555d-b36f-41a7-88f3-7a5774ef2531: expected 200 OK, got 401 Unauthorized
