Loading...
Pages: [1]   Go Down
Author Topic: wifly outside lan  (Read 499 times)
Porlock, UK
Offline Offline
Newbie
DILIGAF
View Profile
Hi everyone have a big problem to solve,
so i have server(spare laptop runing ubuntu server 10.04) running on my local lan which ip is 192.168.1.9(an no-ip address is lmasss.hopto.org) where i uploaded  tank.html but if i accsess my page using lmasss.hopo.org and try to move forward in responce from tank window i get error that my page 192.168.1.14(wifly all code similar to ethernet shield) is not accsesable.question is somhow to do so it still will send data from lmasss.hopo.org to 192.168.1.14 so i can control tank from outside of my lan?
Html page
Code:
<html>
<head>
<title>Arduino wi-fi tank</title>
<style>
html,body{font:normal 14px arial,helvetica;}
#content { width:600px;margin:100px auto;}
#response { font-family:Courier;}
</style>
<script src="http://ajax.googleapis.com/ajax/libs/jquery/1.4.4/jquery.min.js" type="text/javascript"></script>
</head>
<body>
<div id="content">
<table>
<tr><td>&nbsp;</td><td><button rel="n">Fwd</button></td><td>&nbsp;</td></tr>
<tr><td><button rel="w">Left</button></td><td>&nbsp;</td><td><button rel="e">Right</button></td></tr>
<tr><td>&nbsp;</td><td><button rel="s">Back</button></td><td>&nbsp;</td></tr>
</table>
<div style="margin-top:20px;border-top:1px solid #ccc;padding-top:10px;">
<h3>Response from tank</h3>
<div id="response">
<iframe id="tank"></iframe>
</div>
</div>
</div>
<script>
$("button").click(function() {
//$("#response").load("http://192.168.1.14/?dir=" + $(this).attr("rel"));
$("#tank").attr("src", "http://192.168.1.14/?dir=" + $(this).attr("rel"));
</script>
</body>
</html>
arduino code
Code:
 * Web Server
 * (Based on Ethernet's WebServer Example)
 * A simple web server that shows the value of the analog input pins.
#include "WiFly.h"
#include "Credentials.h"
#include <WString.h>
String readString = String(100);
long startTime;
Server server(80);
// set the output pins
int baseMotorEnablePin = 5;
int baseMotorPin1 = 6;
int baseMotorPin2 = 7;
int shoulderMotorEnablePin = 14;
int shoulderMotorPin1 = 15;
int shoulderMotorPin2 = 16;
  WiFly.begin();
  if (!WiFly.join(ssid, passphrase, WEP_MODE)) {
    while (1) {
      // Hang on failure.
    //set the SN754410 pins as outputs:
  pinMode(baseMotorPin1, OUTPUT);
  pinMode(baseMotorPin2, OUTPUT);
  pinMode(baseMotorEnablePin, OUTPUT);
  digitalWrite(baseMotorEnablePin, HIGH);
  pinMode(shoulderMotorPin1, OUTPUT);
  pinMode(shoulderMotorPin2, OUTPUT);
  pinMode(shoulderMotorEnablePin, OUTPUT);
  digitalWrite(shoulderMotorEnablePin, HIGH);
  Serial.print("IP: ");
  Serial.println(WiFly.ip());
  server.begin();
 if(startTime!=0 && millis()-startTime>1500){
     moveStop();
 Client client = server.available();
 if (client) {
   // an http request ends with a blank line
   boolean current_line_is_blank = true;
   String cmd = "";
   int i = 0;
   while (client.connected()) {
     if (client.available()) {
       char c = client.read();
       cmd += c;
       if (cmd == "GET /?dir=n")
        //Serial.println("north");
        client.println("moving forward");
        moveForward();
            delay(100);
    client.stop();
        if (c == '\n') {
          // we're starting a new line
        else if (c != '\r') {
          // we've gotten a character on the current line
          current_line_is_blank = false;
    delay(100);
    client.stop();
void moveForward(){
  startTime=millis();
  digitalWrite(baseMotorPin1, LOW);
  digitalWrite(baseMotorPin2, HIGH);
  digitalWrite(shoulderMotorPin1, LOW);
  digitalWrite(shoulderMotorPin2, HIGH);
void moveStop(){
  startTime=0;
  digitalWrite(baseMotorPin2, LOW);
  digitalWrite(shoulderMotorPin2, LOW);
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
If you are using a router, you will need to port foward incomming traffic to your arduino server.  You will need to run your arduino on a different port than your pc server, such as port 81. In your html page you would have something like below.
http://lmasss.hopo.org:81?dir=
Logged
Why I like my 2005 rio yellow Honda S2000 with the top down, and more!
GOOGLE ADVANCED FORUM SEARCH BELOW!
Go to:  http://www.google.com/advanced_search?hl=en
put in key search words,
use site or domain:  http://arduino.cc/forum
or in a google search box put key words site:http://arduino.cc/forum
Porlock, UK
Offline Offline
Newbie
DILIGAF
View Profile
thanx zoom for you fast replay so say i use port 8888 for arduino and do port forward , thats easy but what to do with html i totaly new to this smiley-sad
edit
just changed port to 8888 and in html file http://lmasss.hopto.org:888?dir= tryed o connect now says cant connect lmasss.hopto.org:8888
edit
restarted router and it worked
Thank you.
« Last Edit: March 04, 2011, 08:08:53 pm by LMas » Logged
Pages: [1]   Go Up
Print
Jump to:
