Topic: MIDI plus USB serial (Read 6536 times) previous topic - next topic
OzGrant
G'day,
I want to send a MIDI command via the USB and then send it out as a MIDI signal.
The MIDI lib used pin 0 and 1, as does the USB port.
Is there a way around this? Even a hardware solution would be welcomed.
WilliamK Govinda
There's a MIDI driver that takes MIDI Data from any Serial port. Since the Arduino sends Serial info via USB too, you could just use that driver and all is done. Just need to google for it, as I don't recall the name, sorry.
Wk
OzGrant
Have three different MIDI lib's all use tx/rx pins. Have another guy blending in NewSoftwareSerial Lib, but he has not finished yet.
So now want to try a Hardware solution, use a FET to switch between the usb chip and the MIDI signal.
Was hoping someone had done this already.
Grumpy_Mike
audioguytodd
Getting MIDI into a PC or Mac through the USB port
http://www.spikenzielabs.com/SpikenzieLabs/Serial_MIDI.html
I have not tried that way because I saw this about it:
Quote
Lag times may be too long for some uses approximately 26ms (see below).
26 ms is just was to long for me.
Grumpy_Mike
Quote
So you believed this without any further details?
The latency will depend on the computer that implements it, so it is a bit rash to make a blanket condemnation of the whole system without further details. See if it works for your setup.
Quote
Is this a real requirement or specmanship?
ccblai
audioguytodd
Quote
Quote
Well, I wasn't saying that nobody should try it. I will give it a try this week just to see.
Yes, <26ms is a requirement in my MIDI controller application. But for others it may not be that big of a deal.
chloris
Low latency audio via usb serial can be achieved with a realtime kernel.
http://www.linuxjournal.com/video/hyper-low-latency-audio-real-time-kernel
Hope it helps.
Have fun.
pjrc
I recently added USB MIDI to Teensyduino.  It requires a AVR chip with native USB, like the one on Teensy.  Regular Arduino doesn't have this, unless you try using the 8u2 chip on Uno (which probably doesn't have enough memory, but if you compile for Teensy 1.0 and get a .HEX file under 4k, it might work).  If you have a compatible board, you should get latency of 1ms or less, and lots of bandwidth, since it's direct 12 Mbit/sec USB.  There's a send_now() function which forces any buffered data USB packet to be immediately made available to the USB host controller.  If you don't call send_now() after sending MIDI messages, the packet gets sent within the next 1ms USB frame.
This USB MIDI code is pretty new.  A few people have used it with success, and I sent and received a bunch of messages to/from Puredata.  If you give it a try, please let me know how it works for you.
Sinborn
The 26 ms is mostly from the Garage Band ->audio drivers->audio hardware part of the signal chain.  I would actually consider that good for a stock audio interface, trying to control a virtual instrument in real time.
I am building a MIDI encoder out of an Uno, and I could use a direct USB connection to a computer.  I may have to test this out, I really don't like how slow standard MIDI is  :P
Grumpy_Mike
Quote
The use OSC - MIDI has been around for more years than I care to remember and it was obsolete 15 years ago. Problem is it is so simple and so ubiquitous.
audioguytodd
Quote
Yes, I have been using MIDI professionally since 1985. It is amazing that the hardware manufacturers agreed to any standard at all. There have been many attempts to 'update' it (MIDI II, etc...) and the manufacturers are reluctant.
It is what it is.  :)
Grag38
if it a serious trouble for use about using Serial AND Midi, you just have to upgrade to Arduino Mega !
It will allow you to use until 4 serial devices.
So from with one Midi I/O and with one Serial, you will get two serial left. Arduino Mega isn't so expensive !
Best regards
Grag38
pjrc
You could also use Teensy, at $16, which uses native USB for very fast Serial.print(), and completely separate serial port you can use for MIDI.
It also has USB MIDI, and can do Serial.print() to the serial montitor window while sending MIDI at USB speed (in that mode it acts as a USB multifunction device for 2 communication channels on a single USB), and those are both separate from the serial port, so you can simultaneously send/receive MIDI there there too.  But there is only 1 serial port capable of 31250 baud MIDI, so if you want 2 actual serial ports, Arduino Mega and Sanguino are the only choices.
For full disclosure, I am involved with PJRC and Teensy.
