Topic: Security camera interesting find? (Read 1 time) previous topic - next topic
ryan53090
Apr 25, 2018, 10:40 am Last Edit: Apr 25, 2018, 11:13 am by ryan53090 Reason: edited to just deleted a pic that was way too blurry
i Took apart one of my Swann security cameras that has a bnc connector. inside i noticed on the board there are 3 plated holes that are labeled I2C right above. is there anyway i can use an arduino on this? what are my options on anyway i could use this in a project?
wvmarle
Three pins for I2C would mean SCL, SDA, GND. GND is easy to figure out, the other two less so. Try connecting it to an Arduino and run the I2C scanner, see if you get anything.
My best guess of the purpose is control of the camera, maybe downloading stills.
Quality of answers is related to the quality of questions. Good questions will get good answers. Useless answers are a sign of a poor question.
RIN67630
If the 3 pins are labeled Vcc, Gnd and CVBS, that would mean
Power, Ground and Composite Video Broadband Signal.
I2C is probably a crappy acronym for Internal CC-TV.
 :smiley-confuse:
Watcher
An analog camera is unlikely to have i2c bus...
lastchancename
#4
Apr 29, 2018, 01:20 pm Last Edit: Apr 29, 2018, 01:22 pm by lastchancename
CVBS. also...
Composite Video, with Burst & Sync
Composite Video, Blanking & Sync
It was distorted over the years by many manufacturers.
Notable difference from CVB with separate Sync
Experienced responders have a nose for laziness, (they were beginners once)... Sure, there are trolls, know-it-alls, and pretenders - but the help you'll get here is about as good as it gets - if you try to help youself!.
Zapro
It might be an analog camera, but the chipset has an I2C EEPROM for settings (Gamma, brightness, line frequency etc)
CVBS is indeed the video output.
// Per.
