Topic: 1 photoresistor 2 leds (sorry for my english) (Read 2957 times) previous topic - next topic
kevindorner
Mar 05, 2011, 12:34 pm Last Edit: Mar 05, 2011, 05:11 pm by kevindorner Reason: 1
I am making a school project until the 14th, but i am new with programming.
A photoresistor controlls the leds. If i place my hand over the photoresistor, led2 goes on.
If I cover it, but then remove my hand, led1 goes on.
PLEASE HELP ME!
task:
1.read the photoresistor
2.wait 0,5 seconds
3.read the photoresistor again
a)if the light that reaches the photoresistor is interrupted for a short time, set led1 high
b)if the light that reaches the photoresistor is interrupted for a long time, set led2 high
=>that means: a)if i move my hand once over it, set led 1 high
b)if i cover it, set led 2 high
I need a programm that looks like this:
int photoIn = 1;
int led1 = 11;
int led2 = 12;
int setPoint = 350;
 pinMode(led1, OUTPUT);
 pinMode(led2, OUTPUT);
 Value = analogRead(photoIn);
 if (Value < setPoint;
     Value > setPoint;)
   digitalWrite(led1, HIGH);
    delay(1000)
   digitalWrite(led1, LOW);
     Value < setPoint;)
   digitalWrite(led2, HIGH);
    delay(1000)
   digitalWrite(led2, LOW);
Coding Badly
Two things...
1. Please do not multi-post.
2. Do you have a question about robotics?
lemio
Nice to see that they are doing Arduino projects on your school :P
The code would be something like this:
int photoIn = 1;
int led1 = 11;
int led2 = 12;
int value = 0;
byte last_value = false;
Change this value to the point where it works,
 it depends on how light the area is.
int setPoint = 350;
  value = analogRead(photoIn);
  if (value < setPoint){
    if (last_value==true){
      digitalWrite(led1,HIGH);
      digitalWrite(led2,LOW);
    last_value = false;
  else{
      digitalWrite(led1,LOW);
      digitalWrite(led2,HIGH);
    last_value = true;
But if you hold your hand for 0.1 seconds this script won't work. This only works if you hold your hand for 0.5 seconds. Success with your project.
kevindorner
I need somethig like this:
int photoIn = 1;
int led1 = 11;
int led2 = 12;
int value = 0;
int setPoint = 350;
      digitalWrite(led1,LOW);}
    else{digitalWrite(led2,HIGH);
      digitalWrite(led2,LOW);}
else{
