Topic: 1 photoresistor 2 leds (sorry for my english) (Read 4611 times) previous topic - next topic
kevindorner
Mar 05, 2011, 12:35 pm Last Edit: Mar 05, 2011, 06:02 pm by kevindorner Reason: 1
I am making a school project until the 14th, but i am new with programming.
A photoresistor controlls the leds. If i place my hand over the photoresistor, led2 goes on.
If I cover it, but then remove my hand, led1 goes on.
PLEASE HELP ME!
task:
1.read the photoresistor
2.wait 0,5 seconds
3.read the photoresistor again
a)if the light that reaches the photoresistor is interrupted for a short time, set led1 high;delay(1000);set led1 low
b)if the light that reaches the photoresistor is interrupted for a long time, set led2 high;delay(1000);set led2 low
=>that means: a)if i move my hand once over it, set led 1 high
b)if i cover it, set led 2 high
I need a programm that looks like this:
int photoIn = 1;
int led1 = 11;
int led2 = 12;
int setPoint = 350;
 pinMode(led1, OUTPUT);
 pinMode(led2, OUTPUT);
 Value = analogRead(photoIn);
 if (Value < setPoint;
     Value > setPoint;)
   digitalWrite(led1, HIGH);
    delay(1000)
   digitalWrite(led1, LOW);
     Value < setPoint;)
   digitalWrite(led2, HIGH);
    delay(1000)
   digitalWrite(led2, LOW);
graynomad
Those if() statements are not valid C code, not even close.
______
Rob
kevindorner
I gave an example i don't know how to programm it right...
Magician
#3
Mar 05, 2011, 05:33 pm Last Edit: Mar 05, 2011, 05:37 pm by Magician Reason: 1
unsigned long pretime =0, newtime =0;
int oldvalue =0, newvalue =0;
oldvalue= newvalue; //
newvalue = analogRead(photoIn);
if (newvalue - oldvalue > 500)
pretime = newtime;
newtime = millis();
 if ((newlalue - oldvalue > 500) && (pretime - newtime > 500) && (pretime - newtime < 3000) )
    delay(1000)
if ((newlalue - oldvalue > 500) && (pretime - newtime > 3000) )
    delay(1000)
kevindorner
Magician
Yes, probably it would not work.
I just try to give a tips, not a programm. The tips are you have a deal with timing,
and should use a time checking subroutine, like millis();
I think in my example there is a timing issue, as it overwrite newvalue any cycle.
And photoresistors are slow devices, so value from the sensor couldn't change fast enough.
Put a delay(500), after last line, it will slow the speed.
GrooveFlotilla
I think a "static" qualifier for oldvalue could be useful
Some people are like Slinkies.
Not really good for anything, but they bring a smile to your face when pushed down the stairs.
hyperkoala
Try using this format:
if(x<y) {
    type your code here;
There is a lesson on photoresistors in the learning section on this website. You may need a voltage divider as a reference for analog input.
