Loading...
Pages: [1]   Go Down
Author Topic: [solved] Arduino to 4051 demux to optocoupler to HomeEasy remote problem  (Read 797 times)
Offline Offline
Newbie
View Profile
Hi all,
I'm trying to control a HomeEasy remote with the Arduino. I followed the instructions on this page
http://www.instructables.com/id/Arduino-Home-automation/step2/Basic-principle/
(Arduino pin --> optocoupler --> remote switch)
However instead of using 8 cables for the 4 on/off remote switches I used a 4051 demux so that I can save some pins on the arduino. I also did not use any LEDs.
If I go from an Arduino pin directly to the optocoupler and send a signal, the remote switches as it should.
If I measure resistance on the optocoupler on the side of the HomeEasy remote... and send something through the demux... I can see that the optocoupler is indeed switched...so the circuit is ok I guess... but the remote does not react at all... smiley-sad
Could this be a problem with too much resistance? What can I do to fix this? Sorry I'm a beginner on circuits.
The optocouplers I am using
http://uk.farnell.com/vishay-semiconductor/ild1/optocoupler-transistor-o-p/dp/1469477
The demuxer I am using
http://at.farnell.com/nxp/hef4051bp/single-8-chan-mux-4051/dp/385347?Ntt=385347
Thanks for your help
--- update
schematics
http://img593.imageshack.us/i/schematic.gif/
--- another update
Heureka! I found it. Turned out that when I had all outputs of the 4051 connected, I was sending always, even when LOW, LOW, LOW as input. But the remote didn't seem to like that and couldn't switch. When I unplugged the wire going from Y0 --> switch 1 OFF it worked!
That means currently I cannot turn off switch 1... but at the moment I only have 3 things to control anyway and I could extend the circuit  smiley
« Last Edit: March 06, 2011, 03:36:22 am by DoctorD » Logged
Manchester (England England)
Online Online
Brattain Member
Solder is electric glue
View Profile
WWW
Quote
The schematic you are using?
Without seeing this it is hard to say.
What I can say is the 4051 is the wrong chip for output multiplexing because:-
1) It is analogue
2) It has no output latch so any signal is only momentary.
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Quote
You are using a current-limiting resistor between the Arduino pin and the opto-coupler input I hope...  And yes without the circuit its impossible to know what's going on.
Logged
Pages: [1]   Go Up
Print
Jump to:
