Author Topic: 120v to nixie tubes!  (Read 1221 times)
Houston
Electronics is just part of life.
I want to make a nixie tube watch and i recently bought 2 in-17's and i started playing with them but i can't quite figure out how to make the arduino output of 5v go to 120-180v that the nixie tube requires... im going to use 2 74141 to control them and im going to use one shift register to give the 4 inputs for each of the 74141's. Can someone help me find out how to power these and how and where the power should be applied, please and thank you! =)
Montreal
Per aspera ad astra.
You have to buy a power supply for nixie.
Loot at :
http://www.ogilumen.com/index.php
You can get idea how to put it all together from their site.
But price too high,
I'd suggest to search in i-net, I've seen as chip as 13$ power supply for nixie.
Houston
Well what components go into it? anything really special i wouldn't be able to buy at an electronics store? like anything i might have to buy on ebay from russia. and i want to make my own because im going to make my own pcb. and which i-net? i've never been there and can't find the url
Montreal
It's pretty simple, arduino provide a digital output
to this chip (binary-decimal decoder). and nixie + resistor + power supply
display a visual performance.
I don't think you have to buy something from russian, but
their stuff could be low in price, they have produced a astonishing quantity of
74141's. during 80's and 90's, (chips o'k after 20 years of storage, warranty more than 25 years,), , with different name, you can read it
It's "K155ID1"
What I'm saying, price 65$ for power supply too high,
you can find chipper, or if money not a question, just touch them
Houston
oh well yeah i understand that part, but i want to actually make it, i want to intergrate it into one of my own projects and i dont have enough space to use another chip... my question is where would you give it the hundred and somthing volts of power, to the 74141 (which i already have) or do you amplify it afterwards or how does that work?
Leonidas-the nixie tube needs at least 150 volts, 120 volts will not work. It is best to use around 170-200 volts for reliability. In order to get this voltage, you must construct a boost circuit. This is from my site documenting the nixie clock I am working on, http://sites.google.com/site/willyager/nixie-clock.
I believe an older (but working) version of the code is there, and so is a picture of the actual circuit. I have run it from both 9 and 12 volts with no problem (I don't think 5 volts will work) and it is stable with 1 or more mA of current draw. It is really just a standard boost circuit with some custom code to regulate the voltage to what I want (right now it's at 166 volts, but higher is probably better).
Boston area, metrowest
Author of "Arduino for Teens". Available for Design & Build services. Now with Unlimited Eagle board sizes!
Have you looked at the links where the flash charge circuit in a disposable camera is used to create the higher voltage?
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17.
Arduino for Teens available at Amazon.com.
Houston
isn't there a way to make the boost circuit without another microcontroller? I havent really programmed anything else but an arduino and thats kinda what i want to stick to... can i use another method to boost the power? lwith just components like a small transformer or something along those lines?
Yes - that's what the disposable camera method does.
http://www.instructables.com/id/Disposibal-Camera-Nixie-Tube-Driver/
Start here & do some research.
Sure, if you want a crappy driver... you can use the arduino to control it pretty easily. Just do some google searching.
