Boston area, metrowest
« on: March 06, 2011, 12:00:53 am » |
Just got word of this part from maxim-ic.com: MAX14830 Quad Serial UART with 128-Word FIFOs and Internal Oscillator Industry's First Quad UART Scalable solution for industrial applications that is ideal for high channel count systems with the flexibility of adding channels Simplified IO-link for master systems with the ability to synchronize the start of selectable UART's transmission by SPI™/I²C global commands Works with up to four master IO-link PHY layer MAX14824s I have a sample of single UART chip, MAX3100 in DIP, that I am looking forward to trying out via its SPI interface. http://www.maxim-ic.com/datasheet/index.mvp/id/1731/t/alI think I may be waiting on a 3.6864MHz Crystal for it, or it came already and I misplaced it.
« Last Edit: March 06, 2011, 12:03:23 am by CrossRoads »
nr Bundaberg, Australia
Online
« Reply #1 on: March 06, 2011, 01:26:34 am » |
That quad sounds nice, I'll have to think of a project that needs one  ______ Rob
« Reply #2 on: March 06, 2011, 02:08:16 am » |
Check the data sheet, they have recommended some parts to go with it for serial port level drivers for lack of a better term. Not available as samples yet tho, and only in 48 TQFN package. http://datasheets.maxim-ic.com/en/ds/MAX14830.pdf 1-4MHz crystal. 1.8MHz only specific callout I saw. The 128 word buffer per UART should make for smooth software operation I would think (vs sucking up a bunch of atmega RAM).
Online
« Reply #3 on: March 06, 2011, 04:45:26 am » |
Very nice, pity about the package, I'm getting better at soldering SMDs but that might be a problem.
_____ Rob
« Reply #4 on: March 06, 2011, 09:35:51 am » |
http://pdfserv.maxim-ic.com/land_patterns/90-0129.PDFYes, 0.5mm pad spacing is a little tight. Could get an adapter like this http://www.dipmicro.com/store/PCB-LQFP48-DIP48Geven gets you pads for a crystal and caps to make a little unit out of it. Order a few other items at the same time to get to $10 and get 10% disount too. Got a friend who could mount it for you?
Online
« Reply #5 on: March 06, 2011, 09:44:13 am » |
Got a friend who could mount it for you? No rush, I think I have enough projects on the go right now. EDIT: Actually now that I think about it, I made a plug-in board for a popular Z80-basedcomputer in the 80s. This computer had no real serial ports just bit-banged serial, so my board replaced the processor with a PCB that relocated the Z80 and added an SIO to give two UARTS and an RTC. Maybe an equivelent for a 328-based Arduino wouldn't be a bad idea. ______ Rob
« Last Edit: March 06, 2011, 09:49:13 am by Graynomad »
« Reply #6 on: March 06, 2011, 12:00:45 pm » |
With ZPUino ( http://www.alvie.com/zpuino) you can have as many serial ports as you wish (however you might need to reduce UART receive fifo, if not enough memory on FPGA). Álvaro
« Reply #7 on: March 06, 2011, 12:43:06 pm » |
and zpuino maybe even procurable some day? I don't see any place to order. Think I will go simpler route for now: max3100 in dip package, add one for each extra serial port needed. Only 8 word FIFO, need to write some code I guess.
Salem, Oregon
Arduino rocks but sometimes it rolls
« Reply #8 on: March 20, 2011, 04:27:14 pm » |
My only problem is how expensive these are. I know you can get samples, but did you see the price is $8 each (qty 1), and you have to buy over 100 to get the price less than $5 each? I'm tempted to simply add an ATMEGA168 (price each $3.33 at qty 1) for the ultimate "extra" UART. With, as you note, a bit of coding. Just a thought. Brad.
« Reply #9 on: March 20, 2011, 06:33:50 pm » |
Geez, how does Maxim expect to sell things? Yeah, those are expensive.
Colombia
« Reply #10 on: April 02, 2011, 08:58:26 pm » |
Yes i wonder if it were possible that in a future the cheap versions of arduino wuold have a bit more uarts and PWM
Online
« Reply #11 on: April 02, 2011, 09:15:04 pm » |
I wish there was a tiny85/84 equivalent with a UART.
I won't be holding my breath though.
______ Rob
« Reply #12 on: April 02, 2011, 10:09:44 pm » |
If MAXIM can offer a whole ATMega328 with a UART for <$6, why can't a standalone UART be offered for even less? Makes you wonder ...
London, England
« Reply #13 on: April 05, 2011, 04:52:22 pm » |
If MAXIM can offer a whole ATMega328 with a UART for <$6, why can't a standalone UART be offered for even less? Makes you wonder ... Economies of scale. They can roll out 328s by the thousand and know they'll sell them. A UART adapter is a more niche item, and so have a more niche price tag.
« Reply #14 on: April 06, 2011, 04:59:36 pm » |
Very nice, pity about the package, I'm getting better at soldering SMDs but that might be a problem. Check out the MAX3110. -j
