Topic: GPS & USB Interface (Read 998 times) previous topic - next topic
3Dawn
I've got an RC car that has a Copernicus GPS on it. If I am at my computer looking at the GPS signals coming in everything works great. If I detach the USB cable and instead let it write to the SparkFun OpenLog the GPS rarely gets a signal lock.
I have checked the voltage levels on the GPS and they look normal in both cases (3.3V). I can't figure out why the GPS doesn't work the same in both cases. I don't have the receive tied to the transmit line on the GPS because I figured I only want to receive data.
Any ideas what might cause this?
kg4wsv
Got a schematic?
Is the ground wire connected?
-j
liudr
When you had the GPS connected to your computer, were you closer to a window or door? My GPS module only works near an open window in my building. Have you tried outdoors?
Serial LCD keypad panel,phi_prompt user interface library,SDI-12 USB Adapter
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
