Loading...
Pages: [1]   Go Down
Author Topic: reading audio files from SD card waveshield  (Read 1679 times)
Cape Town South Africa
Offline Offline
Edison Member
A newbie with loads of posts, and still so much to learn !
View Profile
WWW
I dont know if this is the right place to ask this but I have been using the waveshield based circuit on some devices to play sound clips from a SD card.
One unit failed, and while faultfinding I see that from the circuit diagram that I sort of copied from http://www.ladyada.net/images/wavshield/v11/wave11schem.png  that the 74ls125 is used as a buffer between the 5v data lines from the micro, to the 3v3 SD card.
What I didn't notice was that the 74125 is powered from 3v3 ( the data sheet says min Vcc as 4v75 ? )
The inputs to the chip are 5v but the outputs are less than 2 volts.
I don't know if this is part of the trouble, I havn't got it working yet, but has anyone had problems with this ?
Logged
We live in the era of the smart phones and stupid people.
Offline Offline
Edison Member
View Profile
WWW
I see that the one on the circuit states 74125N  which I cannot even get the specs of on the net ??
Logged
Manchester (England England)
Online Online
Brattain Member
Solder is electric glue
View Profile
WWW
Quote
Why not !!!
http://www.alldatasheet.com/datasheet-pdf/pdf/27397/TI/SN74125N3.html
Logged
Offline Offline
Edison Member
View Profile
WWW
I don't know Mike , they mention the N suffix in many datasheet titles ( like the one you linked ) but do not actually mention it in the sheet, and everything in the sheet states the 4.7v minimum supply.
I recall seeing a post from the guy who wrote the wavehc library, about using the buffer instead of a resistor voltage divider ( as used in the adafruit first waveshield version )
I don't seem to be able to find that post now, but I might try the resistors tomorrow anyway..
Logged
Online Online
Brattain Member
View Profile
WWW
Quote
Yes it will be
If you want a lower working voltage try the 74HC125N
Don't worry about the N suffix.
Logged
Offline Offline
Edison Member
View Profile
WWW
It will work fine with a 3v3 supply, but the input must be 0 - Vcc and the inputs are 5v from the micro....  perhaps I am missing something here.
 http://www.cl.cam.ac.uk/teaching/2003/DigElec/part2-data.pdf
Logged
Online Online
Brattain Member
View Profile
WWW
The 74125N has 5v tolerant inputs, that is it will work with 5V input when only being powered off 3v3.
After some grubbing around I think that part is no obsolete and now you should use something like this:-
http://uk.farnell.com/fairchild-semiconductor/74lcx244msa/ic-74lcx-logic/dp/1504625
Logged
Offline Offline
Edison Member
View Profile
WWW
Thats the one it needs, thanks,  now to see if I can get it in Africa !
Logged
Offline Offline
Edison Member
View Profile
WWW
nearly two years lead time from Farnell  !  ,  I think I will play with the resistors, or perhaps a quad op amp.
But thanks for your time
Logged
Online Online
Brattain Member
View Profile
WWW
OK try 74LCX125 they have those in stock and they have 5 v tolerant inputs.
Logged
Offline Offline
Edison Member
View Profile
WWW
Thanks Mike,  our local agent who mirrors Farnell only has the TSSOP package, but I might be able to get the SOP package through RS Components who operate here. ( I can solder that one, and the production run is too small to warrant outside assembly )
By the way, I got back to fault finding my faulty unit, and it turned out to be a faulty SD card ( 4 weeks old )
I hope addressing them with only 2 volts data doesn't kill them !   The other 3 units are working fine.
I might change the micro in the audio side of the unit to run from 3v3 to resolve the problem, and use a simple resistor/clamp circuit for the address lines which are very slow.
Thanks again for your time..
Logged
Pages: [1]   Go Up
Print
Jump to:
