Topic: Keeping accurate time (Read 33271 times) previous topic - next topic
dcb
Frankly, creating anything other than the most simpletons of clocks without an RTC is highly questionable, unless its the trip than matters moreso than the destination...
Frankly, building a development board with an irregular heartbeat (resonator) to save a dime is highly questionable to me.
Udo Klein
A crystal will be usually ~10 ppm of the mark. So dedicated RTCs are still much better. A resonator will startup faster.
If you insist on precision timing without giving any details on how much accuracy you really need run your Arduino from an external clock and use a PLL to sync it with something like a Trimble Thunderbolt (can be bought for cheap from *bay). If this will not give enought precision then you have an issue ;)
Check out my experiments http://blog.blinkenlight.net
Constantin
I have had great luck / happiness with the DS3231. Great chip, well-documented, easy to interface with, and even a couple of libraries to choose from. In the end though I wrote my own reading / bit-shifting routines since some of the libraries I dealt with didn't do that part perfectly for all the variables that the DS3231 supports. No big deal, there are plenty of examples out there that pointed me in the right direction.
Equally fun was writing a routine that turned these values into a float that reflected the microsoft way of tracking time in Excel.
pito
@Constantin: they claim +/-2ppm/year and 5ppm aging - can you confirm that somehow?? Thnks.
Constantin
Sorry, I hate to be punny but I don't have the time. It's good enough for me...
fat16lib
I did a number of tests with the DS3231.   2 ppm is reasonable If you power it so the temp compensation is maintained.  I use 5 volts all the time since the rate does vary a bit at different voltages.
I used a gps pps signal to test the chip.  My chips do 1 ppm for short times, a few days.  That's as long as I ran them with the gps clock.
Here is a bit more http://forums.adafruit.com/viewtopic.php?f=19&t=17966&p=92197&hilit=ds3231#p92197
pito
@fat16lib: thanks! So you may discipline it via gps and Vcc :).
Constantin
Using a GPS receiver is about as good as you're going to get... hard to beat atomic clocks that operate under close supervision.
odometer
Try just using millis() directly instead of delay(). Something like (warning...untested code):
Code: [Select]
uint32_t lastTime;
void loop(void)
  if ((millis() - lastTime) >= 1000) {
    lastTime += 1000;
    digitalClockDisplay();
This is actually a very smart way of doing it, because you avoid the problems with millisecond rollover.
I wonder why people seem to think that using the built-in millisecond counter inevitably results in problems at rollover.
Alternatively, I would suggest using the microsecond counter.
Code: [Select]
uint32_t lastTime = 0;
const int oneSecond = 1000000;
void loop(void)
  if ((micros() - lastTime) >= oneSecond) {
    lastTime += oneSecond;
This rolls over every 1.2 hours or so, but that is not a problem in this sort of application. Another advantage -- in this application, quite a great one -- is that a clock that runs too fast or too slow is easily adjusted by changing the value of the constant oneSecond. (sort of like the fast/slow lever on a wind-up alarm clock)
Constantin
"const int oneSecond = 1000000;"
Can this work? I'd like to think you need a long for such a big number. Beyond that, wouldn't one have to use 1000000L?
odometer
OOPS! (Well, I told you it was untested code.)
Okay, so try:
Code: [Select]
const long oneSecond = 1000000L;
void loop(void)
Coding Badly
I suspect the compiler is smart enough to know what you intended but, technically, because you are comparing an unsigned value to a signed value the comparison should be extended to 64 bits; which is rather undesirable.  This is probably a better choice...
[font=Courier New]const unsigned long oneSecond = 1000000UL;[/font]
pentius
If your Arduino is powered by an AC outlet (like your clock radio) another source of accurate time is the 60Hz AC power grid.  The long-term accuracy of the 60Hz power is very good.  Possibly even atomic clock good.
If you live in a blackout-prone area (like a rural or Third World area) the Arduino's crystal will, if calibrated, make a pretty good fallback oscillator. In that case, you get to figure out how to design the power supply as well as the software. If you go the 60Hz route, be careful not to let the pulses exceed the 5 volts!
allanhurst
A second a day is 11ppm - not that good.
The chip you use for a clock isn't terribly important - the reference frequency, from whatever
source , defines the accuracy. How good do you want to get?
You can buy 16MHz TCVCXO's good to 0.1ppm over a limited temperature range for about £15.
If you want a lot better, use an off-air reference, as some clocks do, or mains ( whose long term acccuracy is good, but may have significant short-term variations).. we'll leave atomic clocks out of it for now!
regards
Allan.
dwightthinker
A DS3231 is +- 2 mins a year. That is about 4 ppm.
The Mega can only measure 4 us at best.
Even with correction to the drift of the resonator,
one would need to measure for a time length of several
minutes to approach the 4 ppm of the DS3231.
Under normal conditions, I only saw a few us drift every
second, using the DS3231 interrupt to calibrate with.
Most of the other timing errors because of uncertainty
average out over time.
I believe the DS3231 is about as good as is useful with
an arduino.
Using a 0.1ppm TCXO would not be too useful unless
you were talking about time measurement of minutes.
Dwight
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
