Loading...
Pages: [1]   Go Down
Author Topic: Question about DAC with Arduino UNO  (Read 532 times)
Offline Offline
Newbie
View Profile
Hi all,
I am currently working on a project that I need an adjustable voltage (3V, 3.5V, 4V, 4.5V) to feed in to the reference voltage input of the comparator. See the circuit diagram below.
I was surfing the forum and the playground from the Arduino website, there are few ways I can
achieve the DAC from the Arduino.http://arduino.cc/playground/Main/InterfacingWithHardware#adcdac
Using OpAmp
http://www.avdweb.nl/arduino/simple-10-bit-dac.html
R/2R Ladder
http://blog.makezine.com/archive/2008/05/makeit-protodac-shield-fo.html?CMP=OTC-0D6B48984890
Here are my problems.
1) Which method do you recommend for my application? R/2R Ladder or the one using the op amp?
2) Can the ADC output an DC voltage (0 to 5V) ?
3) Am I using the PWM output pin to achieve the process of DAC?
Best Regards,
tayip
« Last Edit: March 08, 2011, 12:24:08 am by tayip » Logged
Montreal
Online Online
Edison Member
Per aspera ad astra.
View Profile
WWW
More info required:
 What is precision of the DAC, in bits (8 - 18) or volts (1mV - 0.5V);
 How fast do you need  to check on your voltage from input?
Logged
Offline Offline
Newbie
View Profile
More info required:
Ideally, I hope I can get 0.1V precision of the DAC.
No longer than 500ms would be fine.
Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
Quote
Given the resolution go for the latter
Quote
No the ADC outputs nothing it is an input.
Quote
You either use PWM or R/2R ladder you don't use both.
You will win no friends on this forum if you cross post. Please don't do it again.
« Last Edit: March 08, 2011, 12:49:59 pm by Grumpy_Mike » Logged
Offline Offline
Newbie
View Profile
Thanks for reminding, I was just not sure which forum to post, so I cross posted.
Quote
I am confused by your answer. For example, in a ideal case, If I input an 1kHz sine wave, 5Vp-p with 2.5V offset to the analog input of the Arduino,
it should read the value from 0 to 1023 level moving up and down. 0Vp-p should read 511 ~ 512.
Then if I output an PWM signal with a fixed value, 511 for example, to the DAC. The DAC should have 2.5V, right?
Logged
Pages: [1]   Go Up
Print
Jump to:
