Topic: Question about DAC with Arduino UNO (Read 6932 times) previous topic - next topic
tayip
Hi all,
I am currently working on a project that I need an adjustable voltage (3V, 3.5V, 4V, 4.5V) to feed in to the reference voltage input of the comparator. See the circuit diagram below.
I was surfing the forum and the playground from the Arduino website, there are few ways I can
achieve the DAC from the Arduino.http://arduino.cc/playground/Main/InterfacingWithHardware#adcdac
Using OpAmp
http://www.avdweb.nl/arduino/simple-10-bit-dac.html
R/2R Ladder
http://blog.makezine.com/archive/2008/05/makeit-protodac-shield-fo.html?CMP=OTC-0D6B48984890
Here are my problems.
1) Which method do you recommend for my application? R/2R Ladder or the one using the op amp?
2) Can the ADC output an DC voltage (0 to 5V) ?
3) Am I using the PWM output pin to achieve the process of DAC?
Best Regards,
tayip
MarkT
Since you only have 4 values a few resistors would suffice.  You'd have to work out suitable values - connect one to Vcc and three others to three pins, each acts as a voltage divider if that pin is low, and is out of the circuit if than pinMode is INPUT.  the divider ratios need to be 3.5/5, 4/5 and 4.5/5...
No the ADC doesn't output anything, its reads voltages only.
With PWM you would have to low pass filter the waveform appropriately, but you do get 256 output levels.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
