Offline
Newbie
« Reply #3 on: March 08, 2011, 01:30:27 pm » |
Right, very basic wiring for now as i just want to get the motors working.
Digital pin 13 to S1 on the motor controller Ground pin to 0V on motor controller
Two 12v 7amph batteries connected in parallel to the + and - of the motor controller. And the two motors are connected.
I have taken it apart and layed it out, it seems interference was causing some of the more strange problems. The motors dont just all over the place any more. Motor 2 runs through fine although will suddenly jump into reverse randomly. Motor 1 either doesnt start, or starts at 10% and will stay there untill 40% and will suddenly jump up. It will then do the same as it goes back down again.
Here is the code
//J. Dingley March 1 2011 For Arduino 328 Duemalinove or similar with a 3.3V accessory power output //i.e. the current standard Arduino board.
#include <SoftwareSerial.h> //must have SoftwareSerial in your arduino library !
//******************** IMPORTANT *************************** //Set dip switches on the Sabertooth for simplified serial and 9600 Buadrate. Diagram of this on my Instructables page// //i.e. DIP switches 1, 3, 5 and 6 set to ON, the remainder set to OFF //******************** IMPORTANT ***************************
//Digital pin 13 is serial transmit pin to sabertooth #define SABER_TX_PIN 13 //Not used but still initialised, Digital pin 12 is serial receive from Sabertooth #define SABER_RX_PIN 12
//set baudrate to match sabertooth dip settings #define SABER_BAUDRATE 9600
//simplifierd serial limits for each motor #define SABER_MOTOR1_FULL_FORWARD 127 #define SABER_MOTOR1_FULL_REVERSE 1
#define SABER_MOTOR2_FULL_FORWARD 255 #define SABER_MOTOR2_FULL_REVERSE 128
//motor level to send when issuing full stop command #define SABER_ALL_STOP 0
SoftwareSerial SaberSerial = SoftwareSerial (SABER_RX_PIN, SABER_TX_PIN ); void initSabertooth (void) { //initialise software to communicate with sabertooth pinMode ( SABER_TX_PIN, OUTPUT );
SaberSerial.begin( SABER_BAUDRATE ); //2 sec delay to let it settle delay (2000); SaberSerial.print(0, BYTE); //kill motors when first switched on }
float level = 0;
int u;
//float k1; //int k2; //int k3; //int k4;
signed char Motor1percent; signed char Motor2percent;
//DIGITAL INPUT //int deadmanbuttonPin = 9; // deadman button is digital input pin 9
void setup() // run once, when the sketch starts { initSabertooth( ); //analogINPUTS
//digital inputs // pinMode(deadmanbuttonPin, INPUT);
Serial.begin(9600); // HARD wired Serial feedback to PC for debugging in Wiring
void set_motor() { unsigned char cSpeedVal_Motor1 = 0; unsigned char cSpeedVal_Motor2 = 0; //set motors using the simplified serial Sabertooth protocol (same for smaller 2 x 5 Watt Sabertooth by the way) Motor1percent = (signed char) level; Motor2percent = (signed char) level;
Serial.print("level "); Serial.println(level);
if (Motor1percent > 100) Motor1percent = 100; if (Motor1percent < -100) Motor1percent = -100; if (Motor2percent > 100) Motor2percent = 100; if (Motor2percent < -100) Motor2percent = -100;
cSpeedVal_Motor1 = map (Motor1percent, -100, 100, SABER_MOTOR1_FULL_REVERSE, SABER_MOTOR1_FULL_FORWARD); cSpeedVal_Motor2 = map (Motor2percent, -100, 100, SABER_MOTOR2_FULL_REVERSE, SABER_MOTOR2_FULL_FORWARD); SaberSerial.print (cSpeedVal_Motor1, BYTE); SaberSerial.print (cSpeedVal_Motor2, BYTE); /* //debugging Serial.print("Motor1percent = "); Serial.print(Motor1percent); Serial.print (" level = "); Serial.println (level); Serial.print("Motor2percent = "); Serial.println(Motor2percent); Serial.print("cSpeedVal_Motor1 = "); Serial.println(cSpeedVal_Motor1); Serial.print("cSpeedVal_Motor2 = "); Serial.println(cSpeedVal_Motor2); */ delay(5000); //5 second delay }
void loop () {
for (u=0; u<5; u++) { level= u * 10; //level = 0 then 10, then 20 until it gets to 50% of max motor power. each set motor routine has 5 sec delay at end of it set_motor(); } for (u=0; u<5; u++) { level= (5- u) * 10; //level = 50 then 40, then 30 then 20 until it gets to 0% of max motor power. each set motor routine has 5 sec delay at end of it set_motor(); } }
Any help would be very much appreciated
