Topic: Arduio-LCD string issues (Read 1 time) previous topic - next topic
tomer1510
Hello Im trying to send a string to arduino from a computer and then from the arduino to the computer
but it keeps sending numbers when I type letters
what code should I use?
floresta
What code were you using?
Don
tomer1510
#include <LiquidCrystal.h>
// Connections:
// rs (LCD pin 4) to Arduino pin 12
// rw (LCD pin 5) to Arduino pin 11
// enable (LCD pin 6) to Arduino pin 10
// LCD pin 15 to Arduino pin 13
// LCD pins d4, d5, d6, d7 to Arduino pins 5, 4, 3, 2
LiquidCrystal lcd(12, 11, 10, 5, 4, 3, 2);
int backLight = 13;    // pin 13 will control the backlight
String g = "";
  pinMode(backLight, OUTPUT);
  digitalWrite(backLight, HIGH); // turn backlight on. Replace 'HIGH' with 'LOW' to turn it off.
  lcd.begin(16,2);
g = Serial.read();
           // columns, rows.  use 16,2 for a 16x2 LCD, etc.
  lcd.setCursor(0,0);           // set cursor to column 0, row 0 (the first row)
  lcd.print(g);
Serial.print(g);  // change this text to whatever you like. keep it clean.
delay(400);
GaryP
Ok, what you see if you open the serial monitor with correct baudrate, can you send anything, do you get it back?
Cheers,
Kari
The only law for me; Ohms Law: U=R*I       P=U*I
Note to self: "Damn! Why don't you just fix it!!!"
