Topic: Arduino and php serial class (Read 3424 times) previous topic - next topic
LastTemplar
Hello again :)
I figured out these days how to control my Arduino with PHP, using the php_serial.class (http://www.phpclasses.org/package/3679-PHP-Communicate-with-a-serial-port.html).
I am able to send messages to Arduino and make it turn on and off two leds.
The problem appears when I want to read the port for messages sent by the Arduino. If I keep the Serial Monitor running I can see that Arduino sends responses and they appear in the Serial Monitor, however I can't seem to read those messages using PHP.
Here is my PHP code:
Code: [Select]
<?php
/* Simple serial script for turning two leds on
and off from the web!
Utilizes the PHP Serial class by Rémy Sanchez <thenux@gmail.com>
(Thanks you rule!!) to communicate with the Arduino Serial!
//check the GET action var to see if an action is to be performed
if (isset($_GET['action'])) {
//Action required
    //Load the serial port class
require("php_serial.class.php");
//Initialize the class
$serial = new phpSerial();
//Specify the serial port to use... in this case COM1
$serial->deviceSet("/dev/ttyACM0"); //SET THIS TO WHATEVER YOUR SERIAL DEVICE HAPPENS TO BE, YOU CAN FIND THIS UNDER THE ARDUINO SOFTWARE'S MENU
    //Set the serial port parameters. The documentation says 9600 8-N-1, so
$serial->confBaudRate(9600); //Baud rate: 9600
$serial->confParity("none");  //Parity (this is the "N" in "8-N-1")
$serial->confCharacterLength(8); //Character length (this is the "8" in "8-N-1")
$serial->confStopBits(1);
//Now we "open" the serial port so we can write to it
$serial->deviceOpen();
//Issue the appropriate command according to the Arduino source code 0=Green On, 1=Green Off, 2=Red On, 3=Red Off.
if ($_GET['action'] == "greenon") {
//to turn the GREEN LED ON, we issue the command
$serial->sendMessage("0\r");
$read $serial->readPort();
echo
$read;
    } else if (
$_GET['action'] == "greenoff") {
//to turn the GREEN LED OFF, we issue this command
$serial->sendMessage("1\r");
echo
$read;
if ($_GET['action'] == "redon") {
//to turn the RED LED ON, we issue the command
$serial->sendMessage("2\r");
echo
$read;
    } else if (
$_GET['action'] == "redoff") {
//to turn the RED LED OFF, we issue this command
$serial->sendMessage("3\r");
echo
$read;
//We're done, so close the serial port again
$serial->deviceClose();
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"
"http://www.w3.org/TR/html4/loose.dtd">
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
<title>Arduino Project 1: Serial LED Control</title>
</head>
<body>
<h1>Arduino Project 1: Serial LED Control</h1>
<p><a href="<?=$_SERVER['PHP_SELF'] . "?action=greenon" ?>">
Click here to turn the GREEN LED on.</a></p>
<p><a href="<?=$_SERVER['PHP_SELF'] . "?action=greenoff" ?>">
Click here to turn the GREEN LED off.</a></p>
<p><a href="<?=$_SERVER['PHP_SELF'] . "?action=redon" ?>">
Click here to turn the RED LED on.</a></p>
<p><a href="<?=$_SERVER['PHP_SELF'] . "?action=redoff" ?>">
Click here to turn the RED LED off.</a></p>
</body>
</html>
And here is the Arduino code:
Code: [Select]
int ledPin13 = 13; // the pin that the green LED is attached to
int ledPin12 = 12; // the pin that the red LED is attached to
int incomingByte;      // a variable to read incoming serial data into
   Serial.begin(9600); // initialize serial communication
   pinMode(ledPin13, OUTPUT);  // initialize the green LED pin as an output
   pinMode(ledPin12, OUTPUT);  // initialize the red LED pin as an output
   // see if there's incoming serial data:
   if (Serial.available() > 0) {
     incomingByte = Serial.read(); // read the oldest byte in the serial buffer
//Preform the code to switch on or off the leds
    if (incomingByte == '0') {
Serial.println("0");
    digitalWrite(ledPin13, HIGH); //If the serial data is 0 turn red LED on
   if (incomingByte == '1') {
   digitalWrite(ledPin13, LOW); //If the serial data is 1 turn red LED off
Serial.println("1");
     if (incomingByte == '2') {
    digitalWrite(ledPin12, HIGH); //If the serial data is 2 turn green LED on
Serial.println("2");
   if (incomingByte == '3') {
   digitalWrite(ledPin12, LOW); //If the serial data is 3 turn green LED off
Serial.println("3");
zoomkat
From what I've seen, there is no easy way to use PHP to obtain data from a serial port.
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
LastTemplar
colbec
It's possible that dio may help you. It is helpful for me in reading serial from Arduino.
http://pecl.php.net/package/dio
