Topic: UTFT Library for Uno and 2.4 tft/lcd shield (Read 960 times) previous topic - next topic
Zyklotrop
Hello there
I have bought an 2.4" tft/lcd shield that fits the UNO I have:
https://www.ebay.com/itm/192163706724
Any Idea what I have to do to start the screen working?
It worked with examples of the UTFT-Library, but now I try to write an own program and the screen is only white. When I use myGLCD.getDisplayXSize(), it gives me the right value.
What do I have to write in UTFT myGLCD()?
Or is the problem something else?
The full code:
Code: [Select]
#include <UTFT.h>
#include <URTouch.h>
// Declare which fonts we will be using
extern uint8_t arial_bold[];
extern uint8_t Inconsola[];
extern uint8_t SevenSegNumFont[];
// ILI9341
UTFT myGLCD(ILI9341_S5P,11,13,10,8,9);  // Remember to change the model parameter to suit your display module!
String xsize, ysize;
  myGLCD.InitLCD();
  myGLCD.clrScr();
  myGLCD.setContrast(32);
  myGLCD.setBrightness(8);
  xsize = myGLCD.getDisplayXSize();
  ysize = myGLCD.getDisplayYSize();
  // myGLCD.setFont(Insola);
  Serial.print(xsize + " " + ysize);
  myGLCD.fillScr(VGA_BLUE);
  myGLCD.setBackColor(VGA_RED);
  myGLCD.fillScr(VGA_GREEN);
  myGLCD.setColor(VGA_BLACK);
  myGLCD.setColor(VGA_BLUE);
  myGLCD.drawLine(10, 10, 100, 100);
  delay(10000);
Thank you for answers!
david_prentice
You have an Mcufriend Uno Shield.   The clue is in the
Quote
2.4" TFT LCD Shield (ili9340) http://www.mcufriend.com
printed on the pcb.
UTFT does not support any 8-bit parallel ILI9341.   And UTFT does not support the shield pinout.
Install Adafruit_GFX and MCUFRIEND_kbv libraries with the IDE Library Manager.
David.
Zyklotrop
#2
May 14, 2018, 09:26 pm Last Edit: May 14, 2018, 09:44 pm by Zyklotrop
Thank you for the fast answer.
Is there a possibility to modify the UTFT for 8-bit ILI9341?
And any manual or list of functions for the mcufriend library?
david_prentice
Most graphics programs use the Adafruit_GFX style of methods.
They are the same methods for circles, lines, printing text, ...
From the library README.md file:
Quote
MCUFRIEND_kbv inherits all the methods from
the Adafruit_GFX class: https://learn.adafruit.com/adafruit-gfx-graphics-library/overview
and Print class: https://www.arduino.cc/en/Serial/Print
If you want UTFT to support ILI9341_8 you will have to ask the Author: Henning Karlsen.
And then write all your programs to use UTFT methods.
David.
