Topic: Compilation error (Read 950 times) previous topic - next topic
VenomSnake
I'm working with a lilytiny cjmcu and i'm triying to add a dht 11. But when i try to complilate the program the arduino IDE said something like "Error compiling for digispark card (default - 16.5mhz)".
Besides of that i also want to see the values of temperature and moisture but the funcion serian doesn't work with the lilytiny...
¿What can i do?
I really would appreciate any kind of help
pert
When you encounter an error you'll see a button on the right side of the orange bar "Copy error messages". Click that button. Paste the error in a message here USING CODE TAGS (</> button on the toolbar).
VenomSnake
#2
May 17, 2018, 06:55 pm Last Edit: May 17, 2018, 06:59 pm by VenomSnake
Code: [Select]
Arduino:1.8.5 (Windows 8.1), Tarjeta:"Digispark (Default - 16.5mhz)"
In file included from C:\Program Files (x86)\Arduino\libraries\DHT-sensor-library-master\DHT_U.cpp:22:0:
C:\Program Files (x86)\Arduino\libraries\DHT-sensor-library-master\DHT_U.h:25:29: fatal error: Adafruit_Sensor.h: No such file or directory
#include <Adafruit_Sensor.h>
compilation terminated.
exit status 1
Error compilando para la tarjeta Digispark (Default - 16.5mhz).
Este reporte podría tener más información con
"Mostrar salida detallada durante la compilación"
opción habilitada en Archivo -> Preferencias.
uxomm
#3
May 17, 2018, 08:50 pm Last Edit: May 17, 2018, 08:52 pm by uxomm
Looks like you have not (properly) installed the sensor's library, the error message says:
You can find the missing library here:
https://github.com/adafruit/Adafruit_Sensor
Download the library by klicking "Clone or download" and "Download ZIP"
Remember the folder you did download the file.
After downloading is complete, open Arduino-IDE and go to
Menu / Sketch / Include Library / Add .ZIP Library...
navigate to the downloaded ZIP file, select it and klick OPEN.
If the language of the Arduino-IDE is set to Spanish it is accordingly:
Programa / Includir Librería / Añadir librería .ZIP...
Always decouple electronic circuitry.
