Topic: Logging serial data in excel through PLX_DAQ not working (Read 413 times) previous topic - next topic
dmharduino
Hi Everyone, thank you in advance for your help and time.
I'm running into an issue when trying to automatically log data in excel using PLX_DAQ. I have an RGB colour sensor connected to my arduino and would like to plot the values with respect to time in excel.
When I open the serial monitor on the arduino it works and prints the values as expected, but when I close the serial monitor, open the PLX_DAQ file and hit connect, it generates the desired labels but never starts data logging.
Any help would be much appreciated.
Taken from here: http://forum.arduino.cc/index.php?topic=437398.0
Nick_Pyner
This is probably just a minor procedural matter, and easily fixed, but you should raise it in the above thread.
It would help if you posted the code in the proper manner, using </> tags.
dmharduino
Sorry, didn't know how to do that, noob here. And okay, I'll mention that, thanks.
#include <Wire.h>
#include "Adafruit_TCS34725.h"
// Pick analog outputs, for the UNO these three work well
// use ~560  ohm resistor between Red & Blue, ~1K for green (its brighter)
#define redpin 3
#define greenpin 5
#define bluepin 6
// for a common anode LED, connect the common pin to +5V
// for common cathode, connect the common to ground
// set to false if using a common cathode LED
#define commonAnode true
// our RGB -> eye-recognized gamma color
byte gammatable[256];
Adafruit_TCS34725 tcs = Adafruit_TCS34725(TCS34725_INTEGRATIONTIME_50MS, TCS34725_GAIN_4X);
  if (tcs.begin()) {
    Serial.println("No TCS34725 found ... check your connections");
    while (1);
  Serial.println("CLEARDATA");
  Serial.println("LABEL,C,R,G,B");
  pinMode(redpin, OUTPUT);
  pinMode(greenpin, OUTPUT);
  pinMode(bluepin, OUTPUT);
  // thanks PhilB for this gamma table!
  // it helps convert RGB colors to what humans see
  for (int i=0; i<256; i++) {
    float x = i;
    x /= 255;
    x = pow(x, 2.5);
    x *= 255;
    if (commonAnode) {
      gammatable[i] = 255 - x;
      gammatable[i] = x;
    //Serial.println(gammatable[i]);
  uint16_t clear, red, green, blue;
  tcs.setInterrupt(true);      // turn off LED
  delay(1000);  // takes 1000ms to read
  digitalWrite(7, HIGH);
  tcs.getRawData(&red, &green, &blue, &clear);
  Serial.print(clear);
  Serial.print(",");
  Serial.print(red);
  Serial.print(",");
  Serial.print(green);
  Serial.print(",");
  Serial.print(blue);
  // Figure out some basic hex code for visualization
  uint32_t sum = clear;
  float r, g, b;
  r = red; r /= sum;
  g = green; g /= sum;
  b = blue; b /= sum;
  r *= 256; g *= 256; b *= 256;
  //Serial.print("\t");
  //Serial.print((int)r, HEX); Serial.print((int)g, HEX); Serial.print((int)b, HEX);
  Serial.println();
  //Serial.print((int)r ); Serial.print(" "); Serial.print((int)g);Serial.print(" ");  Serial.println((int)b );
  analogWrite(redpin, gammatable[(int)r]);
  analogWrite(greenpin, gammatable[(int)g]);
  analogWrite(bluepin, gammatable[(int)b]);
Nick_Pyner
I haven't used PLX for quite a while, but your code looks pretty kosher. You might try changing that variable "clear" to "Fred". Just a guess.
GijKieken
Hey dmharduino
You are missing Serial.print("DATA,"); just above
  Serial.print(",");
  Serial.print(red);
  Serial.print(",");
  Serial.print(",");
  Serial.print(blue);
You should also remove this line Serial.println(); and instead changeyour last Serial.print(blue); in
Serial.println(blue);
The  Serial.print("DATA,") is necessary for Excel to know what to do.
