Loading...
Pages: [1] 2 3 4   Go Down
Author Topic: Saving arrays in EEPROM using ARDUINOMEGA  (Read 2392 times)
0
Offline Offline
Full Member
Arduino rocks
View Profile
Dear all, i need to save a 3 digit # and a 4 digit # in an array[3 digit #]  = (4 digit #) using the EEPROM since I am recieving this data using serial GUI.
Can anyone give any hints on how I can start since I have no idea how to bgin.
Tnx
Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Quote
The number of digits in the numbers is irrelevant, as long as the array type is correct (int, not byte).
Quote
Does this mean that you need an array whose size is somewhere between 111 to 999?
Quote
using the EEPROM
On which Arduino? You may or may not have enough room in EEPROM for a 1000 element int array.
Quote
How? The Arduino doesn't have the native ability to display a GUI.
Logged
Central MN, USA
Offline Offline
Faraday Member
Phi_prompt, phi_interfaces, phi-2 shields, phi-panels
View Profile
WWW
Also, are you using the ATMEGA's onboard EEPROM or external EEPROMs via I2C like 24LC512?
Logged
0
Offline Offline
Full Member
Arduino rocks
View Profile
Yes i know the arduino doesn't have the GUI, but I managed to program it serailly using C# using forms.
That has been sorted out and PAULS, it is tnx to you that I managed it.
I am using the Arduino Mega, having an inbuilt 4kb EEPROM.
Ok so the digits are irrelivant....
What I need is this:
Imagine I recieved an integer serially, say for example 323 (this has been converted from character to an array an to an integer.......) So we have an integer saved in the FLASH memory, i.e. 323.
An then I recieve another # say for example 1234(the same procedure from a char to int.....).So we have another integer saved in the FLASH.
i.e. eg   int reference_no = 323;
            int gas = 1234;
Therefore I need to save these integers in an array in the EEPROM.
This is what I had in mind:
EEPROM:
ADDRESS    VALUE
0               323
1               1234
2
4095
The problem I currently have is when writing for example 323 in the EEPROM in address 0, and when I read it, it isn't 323 saved but 67..???
Is this since the number is greater than 255????
How can I save 323 then??
TNX
Logged
Central MN, USA
Offline Offline
Faraday Member
View Profile
WWW
Just to straight out the terms, FLASH you mentioned in NOT EEPROM.
You need to show the code. I suspect you only read one byte instead of two. I don't know if you wrote two bytes or not with your code. You know, 323 needs two bytes. If you only write the low byte, you get 323 chopped to fit within 255=67
It's probably that.
Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Quote
323 - 256 = ?
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
0
Offline Offline
Full Member
Arduino rocks
View Profile
Ok...so this is the code(it doesn't have the GUI and stuff just an short program...)
Code:
#include <EEPROM.h>
  int reference = 323;
  int gas = 1234;
  int serial;
  EEPROM.write(0,323);
  serial =EEPROM.read(0);
  Serial.print(serial);
  int gas = 1234;
  int serial;
So how can I save 323 then??
tnx
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
Quote
As two bytes, aka "int".
Logged
0
Offline Offline
Full Member
Arduino rocks
View Profile
Sry this is the code..
Code:
#include <EEPROM.h>
  int gas = 1234;
  int serial;
Logged
0
Offline Offline
Full Member
Arduino rocks
View Profile
It is saved as int....
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
Quote
But the EEPROM is only byte wide.
sizeof (byte) == sizeof (int) / 2  (for the Arduino)
« Last Edit: March 09, 2011, 03:15:03 pm by AWOL » Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
EEPROM.write() and EEPROM.read() operate on bytes. To save an int:
Code:
EEPROM.write(0, highByte(reference));
EEPROM.write(1, lowByte(reference));
To read an int:
Code:
int val = (EEPROM.read(0) << 8) + EEPROM.read(1);
You might want to look at the EEPROM_readAnything() and EEPROM_writeAnything() functions:
http://www.arduino.cc/playground/Code/EEPROMWriteAnything
Logged
0
Offline Offline
Full Member
Arduino rocks
View Profile
Ok didn't know this....
So I am using 2 addresses inside the EEPROM now?
That is a problem....
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
Quote
So you've got at least 510 more to play with
That's not a problem - read and understand reply #11
« Last Edit: March 09, 2011, 03:28:38 pm by AWOL » Logged
0
Offline Offline
Full Member
Arduino rocks
View Profile
No it is a problem...
The integer of the reference # varies from 322 to 500 (so in this case it the above procedure needs to be done, if I am correctly understanding)
While the gas # varies from 500 to 1200. Which means I am taking more than one and more addresses
But I need to save these #s in an array which is proportional to the reference # and gas
meaning array[reference] = gas
So how can I know which address it is if each refernce # and gas amount is different entered by the user??
I don't know If I described it correctly....
Logged
Pages: [1] 2 3 4   Go Up
Print
Jump to:
