Topic: Upload sketch only once! (Read 5948 times) previous topic - next topic
a.periz
Hi!
I've made a board with an atmega2560. I'm trying to upload the bootloader with another arduino used as ISP and I get this error:
Code: [Select]
avrdude: verification error, first mismatch at byte 0x3e000
        0x0d != 0xff
avrdude: verification error; content mismatch
but the led on pin 13 digital blinks. So, I tried to upload a sketch and it works only the first time!  :smiley-eek:
If I try twice it fails with a timeout error.
Can somebody help me?
Thank you very much!
johnwasser
After you load ArduinoISP, are you disabling auto-reset?   If the host Arduino resets then the bootloader will be in control, not the ArduinoISP sketch.  One easy way is to hook a 1 to 2 microfarad capacitor between Reset (+) and Ground (-) on the host Arduino after you upload ArduinoISP.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
a.periz
johnwasser
Yes, the resistor should work.
I'm not entirely clear on the problem...  Did you burn a bootloader without error?
You can use the ArduinoISP to upload sketches but I think you need the bootloader to turn control over to the sketch on startup.  If the error was with burning the bootloader you should get that fixed first.
a.periz
No...that's the first problem...when I burn it I get the error in my first post.
I have also tried to upload a sketch via usb (with ft232) and it succeeded, but if I try to upload it again it fails.
I made few tests and I I can upload a sketch only ones after the bootloader, but I think it is a bootloader-related problem because of that error...
Thank You
spycatcher2k
Sounds like a lock issue - after uploading the bootloader, the lock but should be set to 0x0F - maybe an issue with the boards.txt file. Can you post its contents here and we'll havea look at it.
Drew.
http://www.uk-pcb.co.uk - UK Based PCB Fab & Assembly Company
Design & Assembly work undertaken - Arduino repairs & testing - PM for details. Arduino & C# PC programming.
a.periz
I was thinking about a lock, too. But I haven't edited the original board.txt...
This is the mega2560 section:
Code: [Select]
mega2560.name=Arduino Mega 2560
mega2560.upload.protocol=stk500v2
mega2560.upload.maximum_size=258048
mega2560.upload.speed=115200
mega2560.bootloader.low_fuses=0xFF
mega2560.bootloader.high_fuses=0xD8
mega2560.bootloader.extended_fuses=0xFD
mega2560.bootloader.path=stk500v2
mega2560.bootloader.file=stk500boot_v2_mega2560.hex
mega2560.bootloader.unlock_bits=0x3F
mega2560.bootloader.lock_bits=0x0F
mega2560.build.mcu=atmega2560
mega2560.build.f_cpu=16000000L
mega2560.build.core=arduino
Thank You
spycatcher2k
Looks OK ! - Does the sketch you are trying to upload contain !!! in it? - That is the debug switch code to access the extended menu on the 2560 bootloader.
Drew
Coding Badly
How long are the wires between Arduino ISP and the target (atmega2560)?
a.periz
No "!!!"...I just tried with the blink example...
The wires are long about 70cm...mmh..is it too much?
Thank You
Coding Badly
Quote
I've never used anything longer than about 20cm so I can't say for certain if 70cm is or is not a problem.  I can say that 20cm has been a good choice for me.
At this point, you nothing to lose...  Try shorter wires.  Carefully check all connections.
a.periz
Less than 10cm, but nothing change  :|
spycatcher2k
what operating system and version of ide are you using?
a.periz
Mac Os X 10.6.6 and arduino IDE 0022...
I also tried with 0020 with the same result...
Should I try on windows?
Thank you
spycatcher2k
There has been issues with the drivers on mac, try this :
1) Go to System Preferences -> Network
2) If it asks you to add the Arduino (modem device), say cancel
3) Remove the Arduino device from the list if its there
4) Try uploading a sketch!
I only have windows xp - so can't comment if this realy works.
Drew
