Topic: Arduino + EasyDriver weird power question (Read 2296 times) previous topic - next topic
RyanW
hello,
I thought I understood how the wiring should be between the arduino and the easydriver, but when things didn't work out, I moved a ground connection, unplugged the USB cable from the Arduino, and happened upon an odd result. Here is a crude layout of how it is currently wired.
The odd thing is that this wiring gives power to both the EasyDriver AND the Arduino.  Everything seems to run fine, the motor moves as it should, and nothing smells like smoke.  I was under the impression that the M+ on the EasyDriver only fed power to the motor, and that the 5v on the Arduino isn't meant to work as a power input. Am I missing something here? Is it safe to leave it wired like this?
Thanks guys!
RyanW
Ok, I did a little research to refresh my understanding as it's been a few months since I looked this stuff up. It appears I've misremembered a lot of it.  Apparently the 5v connection on the EasyDriver is an output, and the 5v on the Arduino is an input. This, of course, means that everything is working exactly as it should.  Power comes from 9v power supply, the EasyDriver puts out a regulated 5v which powers the arduino via the 5v connection.  Sorry for my confusion =)
RyanW
hmm...  Now I'm reading over the documentation again and I'm changing my mind about the 5v connection on the Arduino.  It sounds to me like this is supposed to supply voltage to power other 5v boards and gets its power from either the USB or Vin or power connector.  While it seems to work when the power is fed to this pin, I think I'll be safer feeding the 5v into the Vin instead.  Please feel free to correct/approve any of my statements.  Thanks =)
AbdulZ
Have you tried this? because i think the two pins you marked on the Arduino are output pins. i'm wondering if those two pins could be used to supply the EasyDriver instead.
mmcp42
there is a little track you can cut on the EasyDriver to disable the onboard 5v, which is indeed derived from motor power
you can then power it from the Arduino (or any other 5v supply)
why would you do that?
well with 9 volt motor power the regulator doesn't have to work too hard
with 30 volts it does get quite warm! (it's dissipating 30-5=25 volts at whatever current you are drawing)
with the onboard 5v enabled, you can draw (up to 50mA as I recall) power to drive, for example, the Arduino
too many options!
there are only 10 types of people
them that understands binary
and them that doesn't
