Topic: Wire.begin() already called (Read 1 time) previous topic - next topic
aherrera
Is there an easy way to know if the Wire.begin() has already been called?
I am creating a library and I want to call it only if it has not been done already.
baum
Open the Arduino source code, and find the wire lib. Now open up wire.cpp, and in wire.begin() add this line:
#define WIRE_BEGIN_CALLED
Then, to test if it has been called:
#ifndef WIRE_BEGIN_CALLED //if not defined
Wire.begin() // will only call if it hasn't been called yet
#endif
Good Luck!
(and sorry this is very late...)
maniacbug
No, that won't do it at all.  #defines are handled by the pre-processor, way before the MCU gets around to calling begin() or not.
From looking at the code, Wire.begin() looks non-destructive, so as long as you haven't done any transmissions yet it looks safe to call it multiple times during setup().
baum
Then use a global boolean 1-bit variable. That should function the same.
virtual1
is there a way to do it WITHOUT modifying the IDE?  I would like to further bulletproof a library that uses wire, because arduinos tend to shoot craps if you forget to begin it.  I'm expecting the user to begin wire for me, and I'd like to know if they forgot and I need to or not.
I know that in most circumstances you can do things like   if (Serial) { bla } to see if the lenoardo serial is open.  anything like that for twi?  I don't mind taking advantage of a side effect somewhere like looking at a weird twi property that is visible to me that just happens to get changed by the begin process.
private_boolean
You can tell if Wire.begin() has been called by looking at the TWCR (Two-Wire Control Register). According to the datasheet, this register is set to 0 at startup and Wire.begin() configures it.
if (TWCR == 0) // do this check so that Wire only gets initialized once
   Serial.println("Beginning wire library...");
   Wire.begin();
