Topic: ENB not working (L298N) (Read 446 times) previous topic - next topic
honging
May 19, 2018, 05:14 pm Last Edit: May 19, 2018, 05:15 pm by honging
// connect motor controller pins to Arduino digital pins
// motor one
int enA = 10;
int in1 = 9;
int in2 = 8;
// motor two
int enB = 5;
int in3 = 7;
int in4 = 6;
  // set all the motor control pins to outputs
  pinMode(enA, OUTPUT);
  pinMode(enB, OUTPUT);
  pinMode(in1, OUTPUT);
  pinMode(in2, OUTPUT);
  pinMode(in3, OUTPUT);
  pinMode(in4, OUTPUT);
void demoOne()
  // this function will run the motors in both directions at a fixed speed
  // turn on motor A
  digitalWrite(in1, HIGH);
  digitalWrite(in2, LOW);
  // set speed to 200 out of possible range 0~255
  analogWrite(enA, 50);
  // turn on motor B
  digitalWrite(in3, HIGH);
  digitalWrite(in4, LOW);
  analogWrite(enB, 50);
  delay(2000);
  // now change motor directions
  digitalWrite(in1, LOW);
  digitalWrite(in2, HIGH);
  digitalWrite(in3, LOW);
  digitalWrite(in4, HIGH);
  delay(2000);
  // now turn off motors
void demoTwo()
  // this function will run the motors across the range of possible speeds
  // note that maximum speed is determined by the motor itself and the operating voltage
  // the PWM values sent by analogWrite() are fractions of the maximum speed possible
  // by your hardware
  // turn on motors
  // accelerate from zero to maximum speed
  for (int i = 0; i < 50; i++)
    analogWrite(enA, i);
    analogWrite(enB, i);
    delay(20);
  // decelerate from maximum speed to zero
  for (int i = 50; i > 0; --i)
    delay(20);
  demoOne();
  demoTwo();
honging
#1
May 19, 2018, 05:24 pm Last Edit: May 19, 2018, 05:26 pm by honging
Here is a video showcasing how it works incorrectly.
Johan_Ha
____________________
If you ask for help and write 'u' instead of 'you' because you think it's convenient, I will write 'no' instead of 'yes'. For same reasons.
