Topic: How to read Yakamoz TDS Multifunctional Tester with Arduino ? (Read 387 times) previous topic - next topic
Actabi
I bought TDS tester and after some test with electronic card I found the output data (see photos).
The first one is when the tester shows 0 and the second picture is when shows 102.
How can I read his data on an arduino?
Thank you very much for your help !!
Paul_KD7HB
Can you post a link describing the data send by the tester?
Paul
Actabi
I found this page who explain what kind of tester is it : https://www.dhgate.com/product/lcd-display-digital-multifunctional-measure/251918928.html
Hope this information can help you to help me :-)
Paul_KD7HB
The only technical data there is the price and the note the device is no longer available for sale. What did you find that I missed?
Paul
Actabi
Sorry, I thought you wanted the references of the product...
The module does not send any data, I was able to have them by welding on pins of the microcontroller (they have no reference) wire. I was able to find the good pins sending to another microcontroller (still no reference) for displaying data.
Have you seen similar data ? If yes, how can I read this with an Arduino ? I don't know where to start for reading this data.
wvmarle
These are not designed to be read by an Arduino or other MCU.
You may be able to reverse engineer the code - start by doing an accurate timing of the signal and see if there are any patterns. Then try to link those patterns with temperature/EC readings. In the end you may be able to decode it.
There are much simpler ways to read EC with an Arduino...
Quality of answers is related to the quality of questions. Good questions will get good answers. Useless answers are a sign of a poor question.
