Topic: How to read PA30 and PA31? (Read 670 times) previous topic - next topic
x-giorgio-x
How can I disable debugging in SWD and read as PA31 (SWDIO) and PA30 (SWCLK) inputs?
x-giorgio-x
How to read IO using register ?
MartinL
#2
May 22, 2018, 12:44 pm Last Edit: May 22, 2018, 12:44 pm by MartinL
Hi giorgio,
To check if a given input pin is high:
Code: [Select]
if (REG_PORT_IN0 & PORT_PA30)
  // Add your code here...
Where the "0" suffix of the REG_PORT_IN0 register denotes port A.
An identical, but alternative syntax is:
Code: [Select]
if (PORT->Group[PORTA].IN.reg & PORT_PA30)
