Topic: joins two codes and alternates between them with a button (Read 319 times) previous topic - next topic
psyshine
hello I have a question, I do not know how to switch between programs with a button, what one does is evade objects autonomously and the other controls it through bluetooth
autonomous robot
Code: [Select]
#include <Servo.h>          //Servo motor library. This is standard library
#include <NewPing.h>        //Ultrasonic sensor function library. You must install this library
//our L298N control pins
const int LeftMotorForward = 7;
const int LeftMotorBackward = 6;
const int RightMotorForward = 4;
const int RightMotorBackward = 5;
//sensor pins
#define trig_pin A1 //analog input 1
#define echo_pin A2 //analog input 2
#define maximum_distance 200
boolean goesForward = false;
int distance = 100;
NewPing sonar(trig_pin, echo_pin, maximum_distance); //sensor function
Servo servo_motor; //our servo name
void setup(){
  pinMode(RightMotorForward, OUTPUT);
  pinMode(LeftMotorForward, OUTPUT);
  pinMode(LeftMotorBackward, OUTPUT);
  pinMode(RightMotorBackward, OUTPUT);
  servo_motor.attach(10); //our servo pin
  servo_motor.write(115);
  delay(2000);
  distance = readPing();
  delay(100);
  delay(100);
  delay(100);
  delay(100);
void loop(){
  int distanceRight = 0;
  int distanceLeft = 0;
  delay(50);
  if (distance <= 20){
    moveStop();
    delay(300);
    moveBackward();
    delay(400);
    moveStop();
    delay(300);
    distanceRight = lookRight();
    delay(300);
    distanceLeft = lookLeft();
    delay(300);
    if (distance >= distanceLeft){
      turnRight();
      moveStop();
    else{
      turnLeft();
      moveStop();
  else{
    moveForward();
int lookRight(){
  servo_motor.write(50);
  int distance = readPing();
  delay(100);
  return distance;
int lookLeft(){
  servo_motor.write(170);
  delay(100);
  return distance;
  delay(100);
int readPing(){
  delay(70);
  int cm = sonar.ping_cm();
  if (cm==0){
    cm=250;
  return cm;
void moveStop(){
  digitalWrite(RightMotorForward, LOW);
  digitalWrite(LeftMotorForward, LOW);
  digitalWrite(RightMotorBackward, LOW);
  digitalWrite(LeftMotorBackward, LOW);
void moveForward(){
  if(!goesForward){
    goesForward=true;
    digitalWrite(LeftMotorForward, HIGH);
    digitalWrite(RightMotorForward, HIGH);
void moveBackward(){
  goesForward=false;
  digitalWrite(LeftMotorBackward, HIGH);
  digitalWrite(RightMotorBackward, HIGH);
void turnRight(){
void turnLeft(){
control by bluetooth
Code: [Select]
//pines de los sensores
#define trig_pin A1
#define echo_pin A2
int distance = 100;
NewPing sonar(trig_pin, echo_pin, maximum_distance); //funciones de los sensores
char getstr;
const int LeftMotorForward = 7;  //Declarar los pines del del motor LN1
const int LeftMotorBackward = 6;  //LN2
const int RightMotorForward = 4;  //LN3
const int RightMotorBackward = 5; //LN4
void _mForward() //Adelante
  Serial.println("go forward!");
void _mBack() //Atras
  Serial.println("go back!");
void _mleft() //Izquierda
  Serial.println("go left!");
void _mright() //Derecha
void _mStop() //Detener
  Serial.println("Stop!");
  Serial.begin(9600); //Declarar los pines de salida
  delay(100);
  delay(50);
  if (distance <= 20){ //Si la distancia es menor o igual a 20 cm
    _mStop(); //Detente
    delay(300);
    _mBack(); //Regresa
    delay(400);
    _mStop(); //Detente
    delay(300);
   else{
  getstr=Serial.read();
 if(getstr=='F')
    _mForward();
  else if(getstr=='B')
    _mBack();
    delay(200);
  else if(getstr=='R')// according to my robot. otherwise L
    _mleft();
    delay(200);
  else if(getstr=='L') // according to my robot. otherwise R
    _mright();
    delay(200);
  else if(getstr=='X')
     _mStop();
int readPing(){
  delay(70);
  if (cm==0){
    cm=250;
  return cm;
PaulS
The usual process for developing a new program is to start with a set of requirements. What are yours?
You will have some state - auto-avoidance or user-(mis)controlled. What will cause a change from one state to the other?
Once you know that, writing the loop() function to call either autoAvoid() or userControl() on each iteration, after determining if a change is needed, is trivial. Writing the functions to be non-blocking isn't that difficult.
