Topic: using interrupt and the pull up resistor on the same pin (Read 8651 times) previous topic - next topic
SouthernAtHeart
Can I use the internal pull-up resistor with an attachInterrupt at the same time on the same pin?
Code: [Select]
attachInterrupt(0, CountPulse, RISING);//turn on interrupt for flow sensor on pin 2
digitalWrite(2, HIGH);  //turn on pull up resistor for flow sensor on pin 2
Will this do away with the need of the 10K resistor in the example for this sensor:
http://www.seeedstudio.com/forum/viewtopic.php?f=4&t=989&start=0
thanks!
CrossRoads
Yes.
Maybe do away. Internal may not have enough oomph to pull up by itself.
nickgammon
The internal pull-ups are spec'd as being 20K to 50K, so maybe typically 35K? Not exactly the same as 10K. It might work, as CrossRoads said.
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
