Loading...
Pages: 1 [2]   Go Down
Author Topic: Help needed to restore original pin settings!  (Read 622 times)
Global Moderator
Dallas
Online Online
Shannon Member
View Profile
WWW
I guess this tells me the FTDI converter is OK
Yes.
Quote
and the processor is toast?
I have no idea.  That is a very strange way to fail.  However, if I were in your shoes, I'd start shopping for a replacement.
Quote
No. I was unsuccessful with the PicStep.
From what I can tell, the PIC-STEP uses RS-232 for communications.  If that is true, the voltage levels are high enough to damage the Arduino.  Your Arduino can act as a "serial converter" but only a "TTL level serial converter" not an "RS-232 serial converter".
Logged
St. Louis, Missouri
Offline Offline
Sr. Member
Arduino rocks
View Profile
Quote
I wasn't using the Pic-Step board, only the chip. So I was going TTL- TTL not TTL- RS-232.
But for now I will get a new Arduino and work up a proper board for the Pic-Step with dedicated serial convertor while I try to figure out what went wrong.
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
