Topic: Moving a cube in 3d, help needed. (Read 2064 times) previous topic - next topic
co2junkie
here is the python code im using for blender 3d to move a 3d cube around one axis, I am using a potentiometer to control the position.. I want to know how can I use multiple potentiometer, like 2 more potentiometer and i can control position of box in 3d ? I am new to python, I don't know how to include multiple analog readings in python for more than one analog inputs from arduino ?
Thankyou
Code: [Select]
import serial
import Blender
serialport = serial.Serial('COM4', 9600)
ob = Blender.Object.Get ('Cube')
Blender.Window.WaitCursor(1)
for i in range(1, 500):
x = serialport.read(size=1)
y = 0.01*ord(x)
#print "y=", y
ob.setLocation(-3*y,2,2.55)
ob.setEuler(0,0,y)
ob.setSize(0.5,0.5,0.5)
Blender.Redraw()
if Blender.Window.TestBreak()==True:
brake()
else:
serialport.close()
Blender.Window.WaitCursor(0)
Arduino code:
Code: [Select]
void setup () {
  Serial.begin (9600);
void loop () {
Serial.print(analogRead(0)/4, BYTE);
delay (40);
Spinlock
How about this:
in python:
Code: [Select]
               y = serialport.read(size=1)
              z = serialport.read(size=1)
and in arduino:
Code: [Select]
void loop () {
Serial.print(analogRead(1)/4, BYTE);
Serial.print(analogRead(2)/4, BYTE);
delay (40);
However, there are some problems with this "protocol":
1) You send positions all the time, even if the potentiometer doesn't move.  You will see this in speed that you can move the cube at the slow baud rate.
2) You have no way of syncronizing the communication.  You will see this when you start the arduino, then start the blender script.  Sometimes your #1 potentiometer will be X, sometimes Y, sometimes Z, because you aren't syncing the xyz.
You could modify your python and arduino code like this to account for #2: (I don't know python - but in C this is what I would do...)
Code: [Select]
// wait for the start data marker (two 0's in sequence)
int icount=0;
do
  c = serialport.read(size=1)
   if(c==0)
     icount++;
icount=0;
} while(icount<2)
// reset of your code here...
and the arduino code for the above python scriptlet:
Code: [Select]
void loop () {
serial.print(0,BYTE);
delay (40);
