Loading...
Pages: [1]   Go Down
Author Topic: reading multiple analog inputs  (Read 1812 times)
Offline Offline
Newbie
View Profile
Hi Guys,
We are working on a project where we are using an arduino uno in order to read battery voltage and solar panel voltage. As we tried this, we run into a big issue: when we try to read in from one analog pin, it works perfectly, but if we read from two analog pins at the same time, none of the two readings are accurate even though we used the same code as before. Please if anybody can shed some light into this issue??? We pretty much just hit a wall as we have tried eveything possible. We will really appreciate your help!
Logged
nr Bundaberg, Australia
Offline Offline
Tesla Member
Scattered showers my arse -- Noah, 2348BC.
View Profile
WWW
Quote
Technically this isn't possible, can you post your code?
______
Rob
Logged
Rob Gray aka the GRAYnomad http://www.robgray.com
Espoo, Finland
Offline Offline
God Member
"Oops, try again..."
View Profile
Shcematics would be a good idea as well. Do they have same ground potential? Are those batteries in parallel or serial?
Cheers,
Kari
Logged
The only law for me; Ohms Law: U=R*I       P=U*I
Note to self: "Damn! Why don't you just fix it!!!"
Offline Offline
Newbie
View Profile
here is the code. Maybe I did not explain myself right. We are reading from two different analog pins on the arduino. They do have the same ground potential.hopefully, this code will give you guys an idea.
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
// variables for input pin and control LED
  int solarV = 7;
  int batteryV= 3;
  float vout = 0.0;
  float vin = 0.0;
  float vin1=0.0;
  float vout1=0.0;
  float R1 = 4.7;
  float R2 = 1.005;
  float R11=4.690;
  float R22= .998;
  float solarPanelVoltage = 0;
  float batteryVoltage =0;
void setup(){
  Serial.begin(9600); // begin sending over serial port
  lcd.begin(20, 4);
  // declaration of pin modes
  analogReference(DEFAULT);
  pinMode(solarV, INPUT);
  pinMode(batteryV, INPUT);
void loop(){
  // read the value on analog input
  //Serial.print("value=");
  //Serial.println(value);
   solarPanelVoltage = analogRead(solarV);
   vout = (solarPanelVoltage * 5.0) / 1024.0;
   vin = vout / (R2/(R1+R2));
  batteryVoltage = analogRead(batteryV);
  vout1=(batteryVoltage * 5.0) / 1024.0;
  vin1= vout1 / (R22/(R11+R22));
 Serial.print("voltage=");
 Serial.println(vin);
 lcd.setCursor(0,0);  //column and row of lcd
 lcd.print("Voltage=");
 lcd.setCursor(8, 0);
 lcd.print(vin);
 lcd.setCursor(13, 0);
 lcd.print("V");
 //delay(1000);
 Serial.print("battery=");
 Serial.println(vin1);
 lcd.setCursor(0,1);  //column and row of lcd
 lcd.print("Battery=");
 lcd.setCursor(8, 1);
 lcd.print(vin1);
 lcd.setCursor(13, 1);
 lcd.print("V");
Logged
Espoo, Finland
Offline Offline
God Member
View Profile
Yes, I understood that. By the code, it seems ok to me, but the schematic would help to understand what is going on. There's probably something floating...?
Kari
Logged
Offline Offline
Tesla Member
View Profile
WWW
Doesn't the solarV in this
Code:
refer to digital pins and in here
Code:
it refers to analog pins. So you are working with different pins.
However I don't think it matters because I think analogRead() will set the pin direction anyway.
______
Rob
Logged
Global Moderator
Boston area, metrowest
Online Online
Brattain Member
Available for Design & Build services
View Profile
WWW
Try putting some delay in between these  reads
Code:
You may be running into this, section 23 of the datasheet, we can't say for sure as no schematic has been posted:
"The analog input circuitry for single ended channels is illustrated in Figure 23-8. An analog
source applied to ADCn is subjected to the pin capacitance and input leakage of that pin, regardless
of whether that channel is selected as input for the ADC. When the channel is selected, the
source must drive the S/H capacitor through the series resistance (combined resistance in the
input path).
The ADC is optimized for analog signals with an output impedance of approximately 10 kΩ or
less. If such a source is used, the sampling time will be negligible. If a source with higher impedance
is used, the sampling time will depend on how long time the source needs to charge the
S/H capacitor, with can vary widely. The user is recommended to only use low impedance
sources with slowly varying signals, since this minimizes the required charge transfer to the S/H
capacitor.
Signal components higher than the Nyquist frequency (fADC/2) should not be present for either
kind of channels, to avoid distortion from unpredictable signal convolution. The user is advised
to remove high frequency components with a low-pass filter before applying the signals as
inputs to the ADC."
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
0
Offline Offline
Newbie
Arduino rocks
View Profile
I had the same problem reading temperature sensors.. The trick when using multiple analog sensors is to read them twice, with a small delay after each read (10ms is good), then discard the first reading. This is because the ADC multiplexer needs switching time and the voltage needs time to stabilize after switching..  Basically the first analogRead call causes the multiplexer to switch, the delay gives the voltage time to stabilize, then your second read should be much more accurate with less jitter. You should have something like this:
Code:
  delay(10);
  delay(10);
  delay(10);
  delay(10);
Logged
'round the world...
Offline Offline
Edison Member
View Profile
WWW
One question popped in my mind now, does the analogPin() function in the Arduino library use the low noise sleeping mode to make a conversion?
Logged
Eu não sou o teu criado. Se respondo no fórum é para ajudar todos mediante a minha disponibilidade e disposição. Responder por mensagem pessoal iria contra o propósito do fórum e por isso evito-o.
Se realmente pretendes que eu te ajude por mensagem pessoal, então podemos chegar a um acordo e contrato onde me pagas pela ajuda que eu fornecer e poderás então definir os termos de confidencialidade do meu serviço. De forma contrária toda e qualquer ajuda que eu der tem de ser visível a todos os participantes do fórum (será boa ideia, veres o significado da palavra fórum).
Nota também que eu não me responsabilizo por parvoíces escritas neste espaço pelo que se vais seguir algo dito por mim, entende que o farás por tua conta e risco.
Dito isto, mensagens pessoais só se forem pessoais, ou seja, se já interagimos de alguma forma no passado ou se me pretendes convidar para uma churrascada com cerveja (paga por ti, obviamente).
Pages: [1]   Go Up
Print
Jump to:
