Topic: Voice control - Arduino - NodeMCU - ESP32 - Raspberry Pi (Read 2389 times) previous topic - next topic
martinius96
Hello there. Today I want to tell you more about my last project, that i edited to final.
I have made web application that support voice-to-text (voice recognition) in real time. It is working with all world languages with available lang code.. For instance: en-US, sk-SK, cs-CZ, de-DE and so on. I have demo for you, it is in English language for try this technology.
Note: Project is only working with Chrome or Samsung Mobile browser!
You can use ESP8266 board (verified working on NodeMCU), I think it will work with ESP8266, Wemos D1 mini etc good. Or you can use Arduino with Ethernet shield W5100, it will work with Wiznet W5200 or W5500 too, you need only full compatible Ethernet2.h library. Web page is universal. If you write your own parser, you can use it with ESP32, RaspberryPi, OrangePi, C.H.I.P, Bigclown and more boards/microcontrolers.
You can use in my demo this hardware:
  • Arduino + Ethernet shield W5100
  • NodeMCU (or similar board)
In my website you have full instructions how to use, read it carefully! You need to start your microphone manually for the first time in settings of webpage.
English voice-to-text translation: https://arduino.php5.sk/PHP_en/
English .ino scripts (working with these demos):
Arduino script with Ethernet shield W5100
Code: [Select]
//Author: Martin Chlebovec
//Nick of author: martinius96
//Website: https://arduino.php5.sk
//Donate: http://paypal.me/chlebovec
#include <SPI.h>
#include <Ethernet.h>
int led = 6;
byte mac[] = { 0xAA, 0xBB, 0xCC, 0x81, 0x7B, 0x4A }; //fyzicka adresa MAC
char serverName[] = "www.arduino.php5.sk"; // webserver
IPAddress ip(192, 168, 1, 254);
EthernetClient client;
String readString;
int x=0; //pocitadlo riadkov
char lf=10; //line feed character
void setup(){
pinMode(led, OUTPUT);
 if (Ethernet.begin(mac) == 0) {
    Serial.println("DHCP nepridelilo adresu, skusam so statickou...");
    Ethernet.begin(mac, ip);
void loop(){
if (client.connect(serverName, 80)) {  //starts client connection, checks for connection
    Serial.println("connected");
    client.println("GET /PHP_en/preklady.txt HTTP/1.1"); //download text
    client.println("Host: www.arduino.php5.sk");
    client.println("Connection: close");  // ukonc HTTP/1.1 spojenie
    client.println(); //koneic requestu
  else {
    Serial.println("Pripojenie neuspesne"); //chyba ak nie som pripojeny
  while(client.connected() && !client.available()) delay(1); //cakaj na data
  while (client.connected() || client.available()) { //pramenna
    char c = client.read(); //dostan bity z buffera
    Serial.print(c); //cela http hlavicka
    if (c==lf) x=(x+1); //pocitaj
    else if (x==12) readString += c; //nasa premenna
if(readString=="On"){
  digitalWrite(led, HIGH);
  }else if(readString=="Off"){
  digitalWrite(led, LOW);
    else{
 Serial.println("Nepodporovana premenna.");
  readString = ("");
  x=0;
  client.stop(); //ukonc spojenie
  delay(5000); //pockaj 5s a vykonaj novu slucku loop
NodeMCU v3 Lolin
Code: [Select]
#include <ESP8266WiFi.h> //kniznica importovana v Arduine core, testovana verzia 2.3.0
#include <WiFiClientSecure.h> //kniznica importovana v Arduine core, testovana verzia 2.3.0
const int led = 16; //GPIO 16 = D0 on NodeMCU board
const char * ssid = "menowifi";
const char * password = "heslowifi";
const char * host = "arduino.php5.sk"; //bez https a www
const int httpsPort = 443; //https port
const char * fingerprint = "13 9f 87 1d b1 85 be e6 bd 73 c1 8d 04 63 58 99 f0 32 43 92"; // odtlacok certifikatu SHA1
  Serial.print("pripajam na wifi siet: ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi uspesne pripojene");
  Serial.println("IP adresa: ");
  WiFiClientSecure client; //funkcia pre HTTPS spojenia
  Serial.print("pripajam sa na server ");
  Serial.println(host);
  if (!client.connect(host, httpsPort)) {
    Serial.println("pripojenie neuspesne");
    return;
  if (client.verify(fingerprint, host)) {
    Serial.println("certifikat zhodny");
    Serial.println("certifikat nezhodny");
  String url = "/PHP_en/preklady.txt";
  Serial.print("poziadavka na adresu: ");
  Serial.println(url);
  client.print(String("GET ") + url + " HTTP/1.1\r\n" +
    "Host: " + host + "\r\n" +
    "User-Agent: NodeMCU\r\n" +
    "Connection: close\r\n\r\n");
  Serial.println("poziadavka vykonana");
  while (client.connected()) {
    String line = client.readStringUntil('\n');
    if (line == "\r") {
      Serial.println("Response prijata");
  Serial.println("Vratena premenna: ");
  Serial.println(line);
  if (line == "On") { //zapnem vystup (rele alebo diodu)
  } else if (line == "Off") { //vypnem vystup (rele alebo diodu)
    Serial.println("Nepodporovana hlasova instrukcia, opakujte prikaz online");
If you are interested for website code, you can contact me on: martinius96@gmail.com
For more informations visit my page and translate it to your language: https://arduino.php5.sk/ovladanie-hlasom.php
Arduino and website programmer
martinius96
