Loading...
Pages: [1]   Go Down
Author Topic: RF Link Kit problem / Virtual Wire  (Read 1174 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
This is the RF Link Kit in question:
http://www.seeedstudio.com/depot/2km-long-range-rf-link-kits-w-encoder-and-decoder-p-321.html
(2KM Long Range RF link kits w/ encoder and decoder)
I am building a wireless link to be able to remotely monitor a greenhouse temperature. The temperature will be represented by an analogue voltage derived from a thermistor, say in range 0-3V.
I am using an Arduino Mega to convert the analogue input to a digital output and plan to feed this into a wireless board. I then have a matching wireless receiver which feeds a Arduino Duemilanove which is connected to the PC via USB.
The wireless transmitter and receiver work OK over the required distance - I can transmit a binary signal to flash an LED on the receiver, using the following code
Code:
// RECEIVER - DUEMILANOVE
  pinMode(A1, INPUT);  // Receiver (using analog as digital for convenience)
  pinMode(13, OUTPUT);
  int sig = digitalRead(A1);
  if (sig) {
    digitalWrite(13, HIGH);
    else{
    digitalWrite(13, LOW);
// TRANSMITTER - MEGA
  pinMode(50, OUTPUT); // transmitter, digital pin
    digitalWrite(50, HIGH);
    digitalWrite(13,HIGH);
    delay(200);
    digitalWrite(50, LOW);
    digitalWrite(13,LOW);
    delay(200);
However I can't figure out how to get it to send a data message representing the analogue signal from the thermistor. My plan was to use virtual wire, but I haven't got the following code to work...
Code:
// RECEIVER
#include <VirtualWire.h>
  vw_set_ptt_inverted(true);
  vw_set_rx_pin(A1);
  vw_setup(500);
  vw_rx_start();
  uint8_t buf[VW_MAX_MESSAGE_LEN];
  uint8_t buflen = VW_MAX_MESSAGE_LEN;
  if (vw_get_message(buf, &buflen))
    Serial.print("Got: ");
    Serial.print(buf[0]);
    delay(100);
// TRANSMITTER
  vw_set_tx_pin(50);
  vw_setup(500);
    char message = 'test';
    vw_send((uint8_t *)&message, strlen(&message));
    vw_wait_tx();
    delay(400);
    delay(400);
I have read something about soldering the pads on the tx and rx boards but I don't see how this would help transmit a message that will vary according to the analogue input to the Arduino....and then pass this on to the PC to decode and translate into a temperature reading.
Can anyone help ? Thanks in advance
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
The pads on the back are just for setting the 'address' of the Tx & Rx units. If you only have this one set, you can leave them as is.
Take out this line, your part does not need it.
For your transmitter, you can load up an array and send it like this:
Code:
     msg[0]=key;                               // load the array with the key character  --> fill this as needed
    digitalWrite(ledPin, true);               // Flash a light to show transmitting
    vw_send((uint8_t *)msg, strlen(msg));     // send the character out
//    Serial.println(key);                // for debugging only
    vw_wait_tx();                             // Wait until the whole message is gone
    delay (50);                               // need some delay or seem to miss key presses
    digitalWrite(ledPin, false);              // turn off the flash of LED
The receive side will get the data as a string of character
Code:
// look for wireless input
if (vw_get_message(buf, &buflen)) // Non-blocking
  int i;
  digitalWrite(ledPin, LOW); // Turn on LED to show working a message
  // Message with a good checksum received, dump it.
  //Serial.println("Got: ");  // Show on PC for debugging
  //    for (i = 0; i < buflen; i++)
  //Serial.print(byte(buf[i]));
  //Serial.println(""); // spaces it out for the monitor
So I think you're pretty close.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
0
Offline Offline
Newbie
Arduino rocks
View Profile
Hi, Thanks for your reply.
I have tried that code but to no avail. Below is the precise code I used.
Does anyone else have any other ideas, perhaps alternative to virtualwire or pointers on how I could implement my own software to achieve my goal?
Thanks
Code:
// TRANSMITTER
const int ledPin = 13;
const int txPin = 50;
  pinMode(ledPin, OUTPUT);
  vw_set_tx_pin(txPin);
  vw_setup(100);
    char msg[0];
    msg[0]='a';
    Serial.println(msg[0]);                // for debugging only
    delay (500);                               // need some delay or seem to miss key presses
Code:
// RECEIVER
void setup(){
  vw_set_rx_pin(A1);
  vw_setup(500);
  vw_rx_start();
void loop(){
  int i;
  for (i = 0; i < buflen; i++){
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
Post your wiring.
This needs to go before setup()
    char msg[0];  << and how can you have an array of size 0? Make this bigger, at least 1. Then msg[0] = 'a' should give vald result
why do you transmit at 100
vw_setup(100);
and receive at 500?
  vw_setup(500);
That's not gonna work.
May not make a difference, but use a digital pin here, even if same pin but called by digital name.
  vw_set_rx_pin(A1);
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Thanks, I'm now using
Code:
const char msg[] = "a";
and have equalized the tx/rx speeds (tried 1,100,500,2000). Wasn't sure what you meant by "even if same pin but called by digital name".
Here is my wiring. Note that I am not using the variable resistor analog signal in my test code, but will be eventually.
Also note that it looks like I am TXing on a pin that should be RXed at A0. In my testing where I was just sending a high/low pulse (which worked), it was in fact RXed at the A1 pin (not sure why). I've tried both A0 and A1 in the code to no avail
« Last Edit: March 12, 2011, 04:34:52 pm by Borb » Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
>>const char msg[] = "a";<<
Try it like this, just to make it simple and more clear what is happening.
char msg[1];   // creates an array of size 1 byte  << put this at top of the sketch before void setup()
msg[0] = "a";  // loads the array with data
>> vw_set_rx_pin(A1); <<
do this as
vw_set_rx_pin(15);  // this is definitely a digital pin now. I don't know how virtualwire and/or compiler react with an analog pin called out.
same for A0 - call it out as
vw_set_tx_pin(14);  // or pin 50 if that is what you are using.
Logged
Pages: [1]   Go Up
Print
Jump to:
