Author Topic: (solved) I want to print IP-address on webpage (Ethernet Shield)  (Read 1441 times)
Hamme, Belgium
When you use
#include <SPI.h>
#include <Ethernet.h>
byte ip[] = { 192, 168, 14, 85};
in your sketch for a web page. How do I get the byte ip[] shown in the web page?
client.print(ip[])
is not the right way, but I can't figure out what is should be
« Last Edit: March 12, 2011, 02:28:24 pm by JO3RI » Logged
Seattle, WA USA
Seattle, WA USA
Have you tried something like this:
client.print(ip[0]);
client.print(".");
client.print(ip[1]);
client.print(".");
client.print(ip[2]);
client.print(".");
client.print(ip[3]);
Not sure what you are trying to do. Do you want an arduino web server to include the IP address in the returned web page?
put in key search words,
Hamme, Belgium
Yep that's what I'm trying to do. When you visit the webpage on the arduino, it should show in html the IP-address of the Arduino webserver (ethernet Shield)
The webpage I'm working on will be a setup-page where you can change the IP address of you Ethernet Shield, but for now I want to know how you can show the actual IP.
http://arduino.cc/forum/index.php/topic,55044.0.html
You may want to look at the DHCP code at the below site to see how info is obtained from a router.
http://gkaindl.com/software/arduino-ethernet
Hamme, Belgium
Ok, Understand your code (I think  smiley-roll)
But, what I simply want to do is, print the IP-address the arduino webservers has, on the webpage, or a 16x2 LCD screen, or de serial console.
May be too simple, but couldn't you also set the ip address as a string variable in the setup part of the code if you have already set it as the ip address to use?
Hamme, Belgium
Yes true, but how? can't I just print the IP have set in  byte ip[] = { 192, 168, 14, 85}; ?
Papendrecht, NL
No, you cant display: byte ip[] = { 192, 168, 14, 85} out of the box.
This is an array of 4 bytes. To make them human readable, you have to translate them to characters.
The Serial.print() function knows how to translate most simple variables to characters, i.e. byte, int, float, char, etc.
The most simple solution - already mentioned - is to store the IP address 2 times, one time as a byte array for the code and one time as a char array (i.e. string) for humans.
Another way is to write a function which translates the byte array to a string.
PaulS has shown you even another way.
'round the world...
Have you tried using itoa()??
char[4] printIP;
itoa((int)ip[0], printIP, 10);
Serial.print(printIP);
Serial.print(".");
//rinse repeat
Eu não sou o teu criado. Se respondo no fórum é para ajudar todos mediante a minha disponibilidade e disposição. Responder por mensagem pessoal iria contra o propósito do fórum e por isso evito-o.
Se realmente pretendes que eu te ajude por mensagem pessoal, então podemos chegar a um acordo e contrato onde me pagas pela ajuda que eu fornecer e poderás então definir os termos de confidencialidade do meu serviço. De forma contrária toda e qualquer ajuda que eu der tem de ser visível a todos os participantes do fórum (será boa ideia, veres o significado da palavra fórum).
Nota também que eu não me responsabilizo por parvoíces escritas neste espaço pelo que se vais seguir algo dito por mim, entende que o farás por tua conta e risco.
Dito isto, mensagens pessoais só se forem pessoais, ou seja, se já interagimos de alguma forma no passado ou se me pretendes convidar para uma churrascada com cerveja (paga por ti, obviamente).
Hamme, Belgium
YES victory. thanks bubulindo (just had to change
char[4] printIP;
into
char printIP[4];
This sketch shows a webpage with the webservers IP-address showing.
#include <SPI.h>
byte mac[] = {
  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[] = {
  192, 168, 14, 85};
char printIP[4];
Server server(80);
  Ethernet.begin(mac, ip);
  server.begin();
  Client client = server.available();
  if (client) {
    boolean current_line_is_blank = true;
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        if (c == 'n' && current_line_is_blank) {
          client.println();
          client.print(printIP);
          client.print(".");
          itoa((int)ip[1], printIP, 10);
          client.print(".");
          itoa((int)ip[2], printIP, 10);
          client.print(".");
          itoa((int)ip[3], printIP, 10);
          break;
        if (c == 'n') {
        else if (c != 'r') {
          current_line_is_blank = false;
    delay(1);
    client.stop();
'round the world...
Java is destroying my poor knowledge of C. I'm sorry. LOL
There's an example on the Networking section of the forum, showing how to print the IP address:
for (int n = 0; n<=3; n++)
            client.print((int)client_ip[n]);
            client.print(".");
The thread is this one:
http://arduino.cc/forum/index.php/topic,54378.0.html
Give it a try and see which is smaller. smiley
Hamme, Belgium
The above doesn't seem to work, it shows numbers, but not the ip address. Your other solution does work. smiley
Now I'm trying to show the MAC-address, but
gives me
222:173:190:239:254:237
which is not hexadecimal, but decimal. I know this is basic stuff, but it's late. Good night  smiley-sleep
'round the world...
use itoa(mac[0], string_mac, 16);
but you need to add the 0x to the string before you print to the screen.
I haven't got my arduino here with me, but it worked for me at home. :S
Hamme, Belgium
It worked as you can see in this topic:
http://arduino.cc/forum/index.php/topic,55044.msg395363.html#msg395363
Thanks bubulindo
