Topic: Adafruit Trinket, Please Help Me... (Read 373 times) previous topic - next topic
crunchydestiny
I'm not much of a programming or even electrical person. I'm making some Nike Back to the Future Mags and I'm using a 3V trinket to power a high torque micro servo.
I have the Adafruit library installed, but the tutorial they provided uses a potentiometer and I want to use buttons to turn the motor one way and the opposite direction. I also want to add these LED's I soldered into the mix and to only turn on when one of the buttons are pushed.
I have spent now a total of 3 days and about 20 hours on this dilemma. I think the wiring is correct but I'm not sure. Every time I upload the sketch the servo twitches about 20 degrees back and forth in a random pattern. Please, please help me. I included some nasty code that I've tried to piece together from random Adafruit tutorials and some pictures of what I'm working with.
Thanks
westfw
The code you posted doesn't compile (doesn't even have a loop() function)...  If you have code that makes the servos twitch, you've gotten further than that, and you should post that code (preferably using code tags.)
Code: [Select]
  SoftServo sketch for Adafruit Trinket.  Turn the potentiometer knob
  to set the corresponding position on the servo
  (0 = zero degrees, full = 180 degrees)
  Required library is the Adafruit_SoftServo library
  available at https://github.com/adafruit/Adafruit_SoftServo
  The standard Arduino IDE servo library will not work with 8 bit
  AVR microcontrollers like Trinket and Gemma due to differences
  in available timer hardware and programming. We simply refresh
  by piggy-backing on the timer0 millis() counter
  Required hardware includes an Adafruit Trinket microcontroller
  a servo motor, and a potentiometer (nominally 1Kohm to 100Kohm
  As written, this is specifically for the Trinket although it should
  be Gemma or other boards (Arduino Uno, etc.) with proper pin mappings
  Trinket:        USB+   Gnd   Pin #0  Pin #2 A1
  Connection:     Servo+  -    Servo1   Potentiometer wiper
#include <Adafruit_SoftServo.h>  // SoftwareServo (works on non PWM pins)
#define SERVO1PIN 0   // Servo control line (orange) on Trinket Pin #0
#define sw1_pin 1
#define sw2_pin 2
Adafruit_SoftServo myServo1, myServo2;  //create TWO servo objects
volatile boolean sw1 = false;
volatile boolean sw2 = false;
uint8_t sw1ButtonState = 0;
uint8_t sw2ButtonState = 0;
uint8_t lastsw1ButtonState = 0;
uint8_t lastsw2ButtonState = 0;
  // Set up the interrupt that will refresh the servo for us automagically
  OCR0A = 0xAF;            // any number is OK
  TIMSK |= _BV(OCIE0A);    // Turn on the compare interrupt (below!)
  myServo1.attach(SERVO1PIN);   // Attach the servo to pin 0 on Trinket
  myServo1.write(90);           // Tell servo to go to position per quirk
  delay(15);                    // Wait 15ms for the servo to reach the position
void checkIfSw1ButtonIsPressed()
    sw1ButtonState   = digitalRead(sw1_pin);
    if (sw1ButtonState != lastsw1ButtonState)
    if ( sw1ButtonState == 0)
      sw1=true;
    delay(50);
   lastsw1ButtonState = sw1ButtonState;
void checkIfSw2ButtonIsPressed()
    sw2ButtonState   = digitalRead(sw2_pin);
    if (sw2ButtonState != lastsw2ButtonState)
    if ( sw2ButtonState == 0)
      sw2=true;
    delay(50);
// We'll take advantage of the built in millis() timer that goes off
// to keep track of time, and refresh the servo every 20 milliseconds
// The SIGNAL(TIMER0_COMPA_vect) function is the interrupt that will be
// Called by the microcontroller every 2 milliseconds
volatile uint8_t counter = 0;
SIGNAL(TIMER0_COMPA_vect) {
  // this gets called every 2 milliseconds
  counter += 2;
  // every 20 milliseconds, refresh the servos!
  if (counter >= 20) {
    counter = 0;
    myServo1.refresh();
crunchydestiny
Sorry, I've made a lot more progress now. That code was straight garbage. Here's something a bit better. I can get the LED to turn on while the button is pressed but I can't get the servo to move at all now.
Code: [Select]
#include <Button.h>       //  Is this being used?
int BUTTON = 2;           //  Button info in pin 2
int pos = 0;              //  Variable to store the servo position
int light = 1;           //  LED in pin 1
#include <Adafruit_TiCoServo.h>
#define SERVOPIN 0        //  Creates servo
Adafruit_SoftServo Lace;  // Naming servo instead of servo1
  pinMode(2, INPUT_PULLUP);
  pinMode(1, OUTPUT);
  Lace.attach(0);
  digitalWrite(2, LOW);
   //******************** Wait for tightening button to be pressed ************************
  int LED = digitalRead(2);     //LED
  if (LED == HIGH) {            //LED
    digitalWrite(light, LOW);   //LED
  } else {                      //LED
    digitalWrite(light, HIGH);  //LED
  if (digitalRead(2) == LOW) {              // Here down is all for the servo
    for (pos = 0; pos < 180; pos += 180){
      Lace.write(pos);
      delay(100);
    if(digitalRead(2) == HIGH)
      for(pos = 180; pos >= 180; pos -= 90)
        Lace.write(pos);
        delay(100);
westfw
You removed the timer code that actually updates the servo output signals.   You need that for them to do anything...
Code: [Select]
  counter += 2;
    counter = 0;
    myServo1.refresh();
crunchydestiny
Sorry, I should've posted this a while ago, but I figured it out.
Code: [Select]
#define SERVO 0       // Servo control line (orange) on Trinket Pin #0
#define SWITCH1 1     // Button 1 on Trinket Pin #1 (Analog 1)
#define SWITCH2 2     // Button 2 on Trinket Pin #2 (Analog 0)
#define LED 3         // LED on Trinket Pin #3 (Analog 3)
Adafruit_SoftServo servo;
const int speed = 5;
 servo.attach(SERVO);   // Attach the servo to pin 0 on Trinket
 pinMode(SWITCH1, INPUT_PULLUP);     // Initialize Trinket Pin #1 as an input with pullup
 pinMode(SWITCH2, INPUT_PULLUP);     // Initialize Trinket Pin #2 as an input with pullup
 pinMode(LED, OUTPUT);               // Initialize the LED pin as an output
 if (! digitalRead(SWITCH1)) {  // if the button is pressed
 servo.write(speed);      // Setting servos in forward motion.
 servo.refresh();
 delay(15);
 if (! digitalRead(SWITCH2)) {  // if the button is pressed
 servo.write(-speed);      // Setting servos in backward motion.
 servo.refresh();
 delay(15);
 digitalWrite(LED, HIGH);
