Topic: How to use PA03/AREF as output ? [SOLVED] (Read 849 times) previous topic - next topic
x-giorgio-x
Jun 01, 2018, 11:39 am Last Edit: Jun 03, 2018, 09:55 am by x-giorgio-x
It is not mapped on arduino.
Set it as output ?
Raise it and lower it?
x-giorgio-x
Solved:
Code: [Select]
PORT->Group[PORTA].DIRSET.reg  =  PORT_PA03;  // Set Out5 digital pin as Output
#define setOut5 PORT->Group[PORTA].OUTSET.reg = PORT_PA03
#define resOut5 PORT->Group[PORTA].OUTCLR.reg = PORT_PA03
westfw
Don't you need to do something with pinmux as well?
x-giorgio-x
I do not know what pinmux is, it's not in the samd datasheet.
This works.
What should do and why?
westfw
See Section 6: "6. I/O Multiplexing and Considerations"
and the PMUXn description in the section on PORT (section 22) ("22.8.12 Peripheral Multiplexing n")
something like (untested!):
Code: [Select]
PORT->Group[PORTA].PINCFG.PMUXEN = 0; // disable alternate peripherals on pin
x-giorgio-x
#5
Jun 05, 2018, 07:47 pm Last Edit: Jun 05, 2018, 07:51 pm by x-giorgio-x
Code: [Select]
72: error: request for member 'PMUXEN' in '1090536448u->Port::Group[0].PortGroup::PINCFG', which is of non-class type 'volatile PORT_PINCFG_Type [32]'
SerialUSB.print(PORT->Group[PORTA].PINCFG.PMUXEN);
Too complicated for my little head.
But does it disable only the PA03 functions? Or what else?
I do not see bit 3 in the code.
I also use PA31 and PA30 as input.
How do I disable SW debug?
Code: [Select]
#define In11 !( REG_PORT_IN0 & PORT_PA31 )  // SWDIO  - PA31
#define In12 !( REG_PORT_IN0 & PORT_PA30 )  // SWDCLK - PA30
westfw
Quote
OK; I actually ran this through the compiler this time.  And you're right - it was missing anything about bit3!
It should be:
Code: [Select]
  PORT->Group[PORTA].PINCFG[3].bit.PMUXEN = 0;
At least, that compiles.   It does seem horribly complex, doesn't it?  Fortunately, everything resolves to constants at compile time, so it doesn't actually generate much code...
x-giorgio-x
Not work.
I believe that that command disables all functions, including IO.
If i read imput on this way:
Code: [Select]
There are a pullup (not wanted), but i read imput.
If i put, this on setp, the pullup is gone, but I do not read the input anymore.
Code: [Select]
  PORT->Group[PORTA].PINCFG[30].bit.PMUXEN = 0;   // Remove other function from In11
  PORT->Group[PORTA].PINCFG[31].bit.PMUXEN = 0;   // Remove other function from In12
