Topic: Laser Cutter - What type of laser is? How to drive the laser power supply? (Read 889 times) previous topic - next topic
axxel
Dear friends!
I found an old 98's laser cutter abondonated in an enterprise. I asked for it and they said me: Leave it at your workshop! It's a present for you! Ohhh yeahhhh, great!!!
I thought this machine Hermes VanGuard Laser 2001 is a classic Co2 laser cutter, working with old parallel port and MS-DOS or windows 9x software, the only thing I have to do is quitting the obsolete electronics and use a classic Arduino UNO with GRBL to free the machine and give it a new oportunity and this tool can be helpful for some projects.
I opened the machine, and I get really surprised when I saw the laser it have! Aparently, looks to be a CO2 laser air cooled... Only I have to understand how I can PWM drive the power supply and here we go! So I desarmed the power supply and I get rally surprised to see the quality of the electonics and these high frequency mosfets! Woooow! Why this technology?... I started to documente myself about this and I conclued this laser isn't a CO2 laser but a ARGON LASER!
The laser power supply pictures:
Here is the input to the "laser tube":
So my firt question is : What type of laser is it?
Unfortunaly, the machine miss some sensors and some unknown stuff (there is free conectors) and it is imposible for me to get working the machine in stock conditions due to these missing parts.
I tried to investigate to see what type of signals I can send to the laser power supply.
The big red and black cable is the general power, 48VDC. The yellow cable have 12VDC, and it is connected to the open door sensors, like a safety.
And the three little cables red, black, and white are going direcly to some microcontroller outputs on the motherboard of he laser cutter.
I tried to send some PWM and low-high states to these 3 little cables with an Arduino, nothing... Impossible to start the laser.
Unfortunately, there is nothing of informations in the web of these devices...
My second question is : Anyone know this brand of laser power supply? Is there a known diagram or instructions of how to use it? Or if there is some instructions of a similar laser at electronics level for the way of how to drive a power supply like that could be helpful for me to get working this laser.
Here some pictures of the FPGAs and Uc Main Board of the laser cutter:
Cheers :)
Paul_KD7HB
There is LOTS of information relating to carbon dioxide laser. Google found it first time.
Paul
Riva
Does the below connector come from the laser module or from the control board?
Big RED/BLACK = power, yellow = door interlock and the thin RED/WHITE/BLACK = ?
Possible scenarios could be...
RED = VCC, BLACK = GND, WHITE = LASER ON/OFF (Voltage levels unknown)
RED/WHITE = Serial, BLACK = GND
NONE OF THE ABOVE
If you could show good images of the board the wires connect to then maybe it will give a better idea of the signals.
Another possibility is the Laser is knackered so you will never get it working.
Don't PM me for help as I will ignore it.
Zapro
It's an RF-excited CO2-laser. 10.6nmum - not Argon-Ion!
// Per.
ChrisTenone
It's an RF-excited CO2-laser. 10.6nm - not Argon-Ion!
// Per.
You mean 10.6 um. 10.6 nm is xray.
What, I need to say something else too?
Zapro
