Topic: 7 segment display datasheet (sa08-11ewa) (Read 3090 times) previous topic - next topic
yan_g
Hello, I'm new to electronics and I would like to know how to decipher this datasheet:
http://datasheet.octopart.com/SA08-11EWA-Kingbright-datasheet-65636.pdf
Especially the pin stuff, which pin do I connect to the ground, etc...
Thanks to anyone willing to help!
AWOL
#1
Mar 12, 2011, 08:47 pm Last Edit: Mar 12, 2011, 08:50 pm by AWOL Reason: 1
It's a common anode device - I don't imagine you'd want to connect any pin to ground.
Connect pins 3, 5, 11, 16 to +5V, and the cathode pins (1, 14, 12, 10, 4, 2, 13, 9) via current limiting resistors to your output pins.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
yan_g
Thanks a lot! By the way that uses a lot of pins, I guess it's a better idea to use a common cathode display?
AWOL
A common cathode display would use exactly the same number of pins
floresta
Quote
Thanks a lot! By the way that uses a lot of pins ....
Think of your digital clock of a few decades ago it used at least four of these, six with a seconds display.  How about a digital multimeter with eight or ten of these?
Don
