Topic: Programming Arduino + Ethernet shield to measure temperature (Read 1 time) previous topic - next topic
mdali1
Hi guys,
Is there any program to run the Arduino board and Im in need to get help in programming my board + Ethernet shield in order to take a human temp using a sensor and get it written in a text file and sent to a selected location using the Ethernet shield.
i have some programs but i dont understand them well because im a beginner.
Thanks in advance,
PaulS
Quote
There are a few...
Quote
Which sensor?
Quote
A text file implies some file storage mechanism. Where do you propose to store the file?
Quote
Selected by who? How will that selection occur?
Quote
One can be a beginner and still understand what a program does.
Targettio
There is an example in the Ethernet library (called BarometricPressureWebServer) which could act as a starting point for you.
If you are complete beginner to coding/electronics/arduino/Ethernet then I would probably start with measuring the temperature and report that via serial and then add the webserver elements latter.
If you are looking for a temperature sensor something like an LM35 (or similar) would be your best bet.
mdali1
thank you guys for replying
im using the sensor AD22103
it does not matter where the data will be stored the important thing is to have them ready and send via the Ethernet shield through radio waves.
for the location im going to be using a tiny tracker to locate the location of the device, and the device will be connected directly to fixed receiver.
i found this code in the net if you guys could check it and let me know if it would work for my project or it would need some editting, here is the code:
An open-source LM35DZ Temperature Sensor for Arduino. This project will be enhanced on a regular basis
(cc) by Daniel Spillere Andrade , http://www.danielandrade.net
http://creativecommons.org/license/cc-gpl
int pin = 0; // analog pin
int tempc = 0,tempf=0; // temperature variables
int samples[8]; // variables to make a better precision
int maxi = -100,mini = 100; // to start max/min temperature
int i;
  Serial.begin(9600); // start serial communication
for(i = 0;i<=7;i++){ // gets 8 samples of temperature
  samples = ( 5.0 * analogRead(pin) * 100.0) / 1024.0;
  tempc = tempc + samples;
tempc = tempc/8.0; // better precision
tempf = (tempc * 9)/ 5 + 32; // converts to fahrenheit
if(tempc > maxi) {maxi = tempc;} // set max temperature
if(tempc < mini) {mini = tempc;} // set min temperature
Serial.print(tempc,DEC);
Serial.print(" Celsius, ");
Serial.print(tempf,DEC);
Serial.print(" fahrenheit -> ");
Serial.print(maxi,DEC);
Serial.print(" Max, ");
Serial.print(mini,DEC);
Serial.println(" Min");
tempc = 0;
delay(1000); // delay before loop
WillR
I am not going to provide details right now. But... I have done a similar project with a lot more data than temperature and have it working by sending the data in UDP packets (Ethernet).
So yes. It is a workable project.
Just another Hacker
Targettio
The code you have provided is for an LM35 temperature sensor. It checks the temperature once a second reports the a sort of moving average temperature and the max/min temperatures detected over the serial connection.
That's not really what you want. From my understanding you want a user (or server) to request the temperature from the arduino (via Ethernet) and the arduino will report it back.
If that's the case you simply need a basic Ethernet script (see webserver.pde in the Ethernet library) with an analogread() to get the output of the sensor (and a bit of maths to convert the sensor input into a temperature).
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
