I found this code somewhere. Can't remember where (sorry for not acknowledging the contributor
#define HMC5883_WriteAddress 0x1E // i.e 0x3C >> 1
#define HMC5883_ModeRegisterAddress 0x02
#define HMC5883_ContinuousModeCommand 0x00
#define HMC5883_DataOutputXMSBAddress 0x03
int regb=0x01;
int regbdata=0x40;
int outputData[6];
Wire.begin(); //Initiate the Wire library and join the I2C bus as a master
int i,x,y,z;
double angle;
Wire.beginTransmission(HMC5883_WriteAddress);
Wire.send(regb);
Wire.send(regbdata);
Wire.endTransmission();
Wire.beginTransmission(HMC5883_WriteAddress); //Initiate a transmission with HMC5883 (Write address).
Wire.send(HMC5883_ModeRegisterAddress); //Place the Mode Register Address in send-buffer.
Wire.send(HMC5883_ContinuousModeCommand); //Place the command for Continuous operation Mode in send-buffer.
Wire.endTransmission(); //Send the send-buffer to HMC5883 and end the I2C transmission.
delay(100);
Wire.requestFrom(HMC5883_WriteAddress,6); //Request 6 bytes of data from the address specified.
//Read the value of magnetic components X,Y and Z
if(6 <= Wire.available()) // If the number of bytes available for reading be <=6.
for(i=0;i<6;i++)
outputData
=Wire.receive(); //Store the data in outputData buffer
x=outputData[0] << 8 | outputData[1]; //Combine MSB and LSB of X Data output register
z=outputData[2] << 8 | outputData[3]; //Combine MSB and LSB of Z Data output register
y=outputData[4] << 8 | outputData[5]; //Combine MSB and LSB of Y Data output register
angle= atan2((double)y,(double)x) * (180 / 3.14159265) + 180; // angle in degrees
Refer the following application note for heading calculation.
http://www.ssec.honeywell.com/magnetic/datasheets/lowcost.pdf
atan2(y, x) is the angle in radians between the positive x-axis of a plane and the point
given by the coordinates (x, y) on it.
This sketch does not utilize the magnetic component Z as tilt compensation can not be done without an Accelerometer
----------------->y
x
N
NW | NE
W----------E
SW | SE
S
//Print the approximate direction
Serial.print("You are heading ");
if((angle < 22.5) || (angle > 337.5 ))
Serial.print("South");
if((angle > 22.5) && (angle < 67.5 ))
Serial.print("South-West");
if((angle > 67.5) && (angle < 112.5 ))
Serial.print("West");
if((angle > 112.5) && (angle < 157.5 ))
Serial.print("North-West");
if((angle > 157.5) && (angle < 202.5 ))
Serial.print("North");
if((angle > 202.5) && (angle < 247.5 ))
Serial.print("NorthEast");
if((angle > 247.5) && (angle < 292.5 ))
Serial.print("East");
if((angle > 292.5) && (angle < 337.5 ))
Serial.print("SouthEast");
Serial.print(": Angle between X-axis and the South direction ");
if((0 < angle) && (angle < 180) )
angle=angle;
angle=360-angle;
Serial.print(angle,2);
Serial.println(" Deg");
delay(100);
