Loading...
Pages: [1]   Go Down
Author Topic: simplified firmata on digital  (Read 392 times)
Singapore
Offline Offline
Newbie
Arduino rocks
View Profile
Hi dude,
      I'm trying to use firmata (digital) on my thermometer project but still having some problem. Actually, still unable to understand about firmata communication. Anyone help me explain about digital section of firmata communication. What I actually want to do is to read one analog port and status of two digital ports via firmata in 10 ms of every second. The rest 990 ms is used for user interface and display purpose. I've done some modification on firmata standard for uno file in order to understand for me as follow:
Code:
#include <Firmata.h>
/* has the command arrived? */
boolean firstCommand = false;
int dataOnSerial = 0;
boolean statusLed = false;
/* analog inputs */
int analogInputsToReport = 0; // bitwise array to store pin reporting
/* digital input ports */
byte reportPINs[TOTAL_PORTS];       // 1 = report this port, 0 = silence
byte previousPINs[TOTAL_PORTS];     // previous 8 bits sent
/* pins configuration */
byte pinConfig[TOTAL_PINS];         // configuration of every pin
byte portConfigInputs[TOTAL_PORTS]; // each bit: 1 = pin in INPUT, 0 = anything else
int pinState[TOTAL_PINS];           // any value that has been written
/* timer variables */
unsigned long currentMillis;        // store the current value from millis()
unsigned long previousMillis;       // for comparison with currentMillis
int samplingInterval = 19;          // how often to run the main loop (in ms)
unsigned long toggleMillis;
void toggleLed()
  if (millis() - toggleMillis > 500) {
    statusLed = !statusLed;
    digitalWrite(13, statusLed);
    toggleMillis = millis();
void outputPort(byte portNumber, byte portValue, byte forceSend)
  // pins not configured as INPUT are cleared to zeros
  portValue = portValue & portConfigInputs[portNumber];
  // only send if the value is different than previously sent
  if(forceSend || previousPINs[portNumber] != portValue) {
    Firmata.sendDigitalPort(portNumber, portValue);
    previousPINs[portNumber] = portValue;
void checkDigitalInputs(void)
  if (TOTAL_PORTS > 2 && reportPINs[2]) outputPort(2, readPort(2, portConfigInputs[2]), false);
  if (TOTAL_PORTS > 13 && reportPINs[13]) outputPort(13, readPort(13, portConfigInputs[13]), false);
  if (TOTAL_PORTS > 14 && reportPINs[14]) outputPort(14, readPort(14, portConfigInputs[14]), false);
  if (TOTAL_PORTS > 15 && reportPINs[15]) outputPort(15, readPort(15, portConfigInputs[15]), false);
/* sets the pin mode to the correct state and sets the relevant bits in the
 * two bit-arrays that track Digital I/O and PWM status
void setPinModeCallback(byte pin, int mode)
  switch(mode) {
    case INPUT:
      if (IS_PIN_DIGITAL(pin)) {
        pinMode(PIN_TO_DIGITAL(pin), INPUT); // disable output driver
        digitalWrite(PIN_TO_DIGITAL(pin), LOW); // disable internal pull-ups
        pinConfig[pin] = INPUT;
    case OUTPUT:
        digitalWrite(PIN_TO_DIGITAL(pin), LOW); // disable PWM
        pinMode(PIN_TO_DIGITAL(pin), OUTPUT);
        pinConfig[pin] = OUTPUT;
    default:
      Firmata.sendString("Unknown pin mode"); // TODO: put error msgs in EEPROM
  // TODO: save status to EEPROM here, if changed
void digitalWriteCallback(byte port, int value)
  byte pin, lastPin, mask=1, pinWriteMask=0;
  if (port < TOTAL_PORTS) {
    // create a mask of the pins on this port that are writable.
    lastPin = port*8+8;
    if (lastPin > TOTAL_PINS) lastPin = TOTAL_PINS;
    for (pin=port*8; pin < lastPin; pin++) {
      // do not disturb non-digital pins (eg, Rx & Tx)
        // only write to OUTPUT and INPUT (enables pullup)
        // do not touch pins in PWM, ANALOG, SERVO or other modes
        if (pinConfig[pin] == OUTPUT || pinConfig[pin] == INPUT) {
          pinWriteMask |= mask;
          pinState[pin] = ((byte)value & mask) ? 1 : 0;
      mask = mask << 1;
    writePort(port, (byte)value, pinWriteMask);
void reportDigitalCallback(byte port, int value)
    reportPINs[port] = (byte)value;
  // do not disable analog reporting on these 8 pins, to allow some
  // pins used for digital, others analog.  Instead, allow both types
  // of reporting to be enabled, but check if the pin is configured
  // as analog when sampling the analog inputs.  Likewise, while
  // scanning digital pins, portConfigInputs will mask off values from any
  // pins configured as analog
void sysexCallback(byte command, byte argc, byte *argv)
  switch(command) {
  case CAPABILITY_QUERY:
    Serial.write(START_SYSEX);
    Serial.write(CAPABILITY_RESPONSE);
    for (byte pin=0; pin < TOTAL_PINS; pin++) {
        Serial.write((byte)INPUT);
        Serial.write(1);
        Serial.write((byte)OUTPUT);
        Serial.write(1);
      Serial.write(127);
    Serial.write(END_SYSEX);
  case PIN_STATE_QUERY:
    if (argc > 0) {
      byte pin=argv[0];
      Serial.write(PIN_STATE_RESPONSE);
      Serial.write(pin);
      if (pin < TOTAL_PINS) {
        Serial.write((byte)pinConfig[pin]);
Serial.write((byte)pinState[pin] & 0x7F);
if (pinState[pin] & 0xFF80) Serial.write((byte)(pinState[pin] >> 7) & 0x7F);
if (pinState[pin] & 0xC000) Serial.write((byte)(pinState[pin] >> 14) & 0x7F);
  byte i;
  Firmata.setFirmwareVersion(2, 2);
 // Firmata.attach(ANALOG_MESSAGE, analogWriteCallback);
  Firmata.attach(DIGITAL_MESSAGE, digitalWriteCallback);
 // Firmata.attach(REPORT_ANALOG, reportAnalogCallback);
  Firmata.attach(REPORT_DIGITAL, reportDigitalCallback);
  Firmata.attach(SET_PIN_MODE, setPinModeCallback);
  Firmata.attach(START_SYSEX, sysexCallback);
  // TODO: load state from EEPROM here
  /* these are initialized to zero by the compiler startup code
  for (i=0; i < TOTAL_PORTS; i++) {
    reportPINs[i] = false;
    portConfigInputs[i] = 0;
    previousPINs[i] = 0;
  for (i=0; i < TOTAL_PINS; i++) {
    if (IS_PIN_ANALOG(i)) {
      // turns off pullup, configures everything
      setPinModeCallback(i, ANALOG);
      // sets the output to 0, configures portConfigInputs
      setPinModeCallback(i, OUTPUT);
  // by defult, do not report any analog inputs
  Firmata.begin(57600);
  /* send digital inputs to set the initial state on the host computer,
   * since once in the loop(), this firmware will only send on change */
    outputPort(i, readPort(i, portConfigInputs[i]), true);
  /* init the toggleLed counter */
  pinMode(13, OUTPUT);
  byte pin, analogPin;
  /* DIGITALREAD - as fast as possible, check for changes and output them to the
   * FTDI buffer using Serial.print()  */
  checkDigitalInputs();
  //XXX: hack Firmata to blink until serial command arrives
  dataOnSerial = Firmata.available();
  if (dataOnSerial > 0 && !firstCommand) {
    firstCommand = true;
  //XXX: do the blink if the first command hasn't arrived yet
  //     configures pin 13 as output and then back as input
  if (!firstCommand) {
    toggleLed();
  /* SERIALREAD - processing incoming messagse as soon as possible, while still
   * checking digital inputs.  */
  while(dataOnSerial) {
    Firmata.processInput();
  /* SEND FTDI WRITE BUFFER - make sure that the FTDI buffer doesn't go over
   * 60 bytes. use a timer to sending an event character every 4 ms to
   * trigger the buffer to dump. */
thanks in adv,
pak
« Last Edit: March 13, 2011, 05:46:54 am by pak » Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
You've changed one end of a cooperative data exchange protocol. You haven't even showed the code on the other end.
Your problems are more likely in how the hardware is connected to the Arduino, or in how the PC application is trying to use Firmata on the Arduino, than they are in the Firmata sketch itself.
When you change things in a sketch like this, you should clearly identify what you have changed, and why. If the what and why are reasonable and necessary, the standard sketch can be modified, so everyone benefits.
It's also important to describe, when posting on the forum, what you need help with.
Logged
Singapore
Offline Offline
Newbie
Arduino rocks
View Profile
Hi Paul,
       Thank for your response, I've already mentioned about what I need help.
Quote
What I actually want to do is to read one analog port and status of two digital ports via firmata in 10 ms of every second. The rest 990 ms is used for user interface and display purpose. Just asking for help about simplified firmata communication
My project is a merely temperate monitoring project. It has 7 segment display, 3 buttons, one relay, one buzzer and rs232 link to pc. That's why I don't describe about code of the temperature monitoring project. Everybody know about it, I believe. What I want to use firmata protocol is to display temperature value and status of relay and buzzer in 10ms of every second. So callback function is necessary to use for that. The rest 990 ms is for 7 seg and button interrupt.
I've read about firmata protocol at http://arduino.cc/forum/index.php/topic,39941.0.html and http://firmata.org/wiki/V2.2ProtocolDetails.
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
Do you want to address this issue, or do you want to keep evading it?
Logged
Pages: [1]   Go Up
Print
Jump to:
